Cold Air Inductions
Old 11-10-2013, 05:45 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
New Universal magnetic jack pad
We now have a Universal jack pad along with standard and heavy use pads we sell. The universal will fit Chargers, Fords with the pinch weld opening of only 2 inch so we put a base on them. The heavy use pads fit only cars with 3 inch pinch weld openings and do not need a base, the 2 inch does. The universal is what to have if you have other cars you want to use it on, if only Camaros or Challengers then the universal is not needed.
http://www.camaro5.com/forums/showthread.php?t=327518
Skylane765 is offline   Reply With Quote
Old 11-10-2013, 05:46 PM   #2
Skylane765
Skylane765's Avatar
Here it is on the ZL1. They work great on a lift also as do all our other jack pads.
