Cold Air Inductions
Old 11-10-2013, 05:49 PM   #1
chuckclanton
Drives: 2016 Camaro 1/SS
1LE strut & shock P/Ns not listed on GM!
As I want to buy just struts, shocks & rear shock mounts, I check on
GM parts site and got a big zero! 22812982/3 struts, 22981391 r shocks and 22922445/6 rear shock mounts. Maybe they won't separate the track kit? For my 2014 SS that I don't want to lower but like the monotubes. Already have the ZL1 sway bars on the way from Parts Taxi. I have a staggered wheel/tire setup, and I want to use my stock springs which are the same as the 1LE.
chuckclanton is offline   Reply With Quote
Old 11-10-2013, 10:52 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2014 Summit White 2SS/RS 1LE
Your dealer should be able to order them if nothing else.
2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, Elite Gen2 CC, ZL1 splash guards, ZL1 pedals, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's on HoosierStone Tires, Previous Car: 2012 Black 2LT/RS, Fully 1LE swapped
Wichita Region SCCA Autocross #23 FS
ICTsccaCamaro is offline   Reply With Quote
Old 11-11-2013, 12:18 AM   #3
intensifi
Drives: '12 2LT Convertible
GMPP catalog lists the bill of materials
Mods: GM Locking Gas Cap, RS License Plate Frame
intensifi is offline   Reply With Quote
Old 11-11-2013, 06:12 AM   #4
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
This should help.
Sftshldr
Beast Rider
Drives: 2013 Blk/Blk 1SS Auto
View My Garage
iTrader Rating: 0 reviews
ZL1 Part Numbers:
Strut Tower Brace (LT, SS, 1LE) - 22756880
Wheel Hubs (ZL1, 1LE) (4) - 25954415
Front Coil Spring (SS, 1LE) (2) - 92245257
Front Strut (1LE) (passenger side) - 22812984
Front Strut (1LE) (driver side) - 22812985
Front Sway Bar (1LE) - 22812946
Front Sway End Link (SS, ZL1, 1LE) (passenger side) - 22842515
Front Sway End Link (SS, ZL1, 1LE) (driver side) - 22842516
Rear Shock Mount (ZL1, 1LE) (passenger side upper) - 22836734
Rear Shock Mount (ZL1, 1LE) (driver side upper) - 22836727
Rear Coil Spring (SS, 1LE) (2) - 92195466
Rear Shocks (1LE) (2) - 22812987
Rear Sway Bar (ZL1, 1LE) - 22786260
Rear Sway Bar Endlink (SS, ZL1, 1LE) (2) - 22761221
Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion)
Rear Toe Link (ZL1, 1LE) (2) - 22845487
3.91 Gears only ( 1LE ) - 22813040
Front Splitter kit ( 1LE ) - 22950575
Wheels 20x10 Black ( ZL1-1LE ) - 22798741
Wheels 20x11 Black ( ZL1-1LE ) - 22798743
2012-13 "Exposed" Hood Insert - 22845156
2013 Ashen Gray Painted Hood Insert - 22959777
Shifter Boot-Suede - 24261464
Shifter Boot-Leather - 24263725
Steering Wheel-Suede - 22813848
Steering Wheel-Leather - 22813852
Rear Spoiler - 22828467
Fog Light-LH/RH - 10335108
Fog Light Bezel-LH - 22895339
Fog Light Bezel-RH - 22895338
Front Lower Fascia/Splitter - 22894223
Front Fascia - 22831868
Wheel Polished Front - 9599037
Wheel Polished Rear - 9599038
Emblem "ZL1" Hood - 22830718
Emblem "ZL1" RR.Deck - 22830719
Fender:RH - 20943622
Fender:LH - 20943621
Liner-Frt Whl Hse-LH - 20952837
Liner-Frt Whl Hse-RH - 20952838
Valance Kit For Front Wheel House-Liners - 22757643 (These are the two wheel liner extensions on the bottom, they come in a kit and dealer must install these as part of the PDI procedure)
Extension-Frt Whl Hse-LH - 22895341
Extension-Frt Whl Hse-RH - 22895340 (These are the pieces that "stick-out" of the front of the wheelhouse-liners,also called "guards")
Hood - 22824393
ZL1 Grille - 22893907
ZL1 Grille Emblem - 22830717
ZL1 Headlamp Housing - LH-20981021 / RH-20981022 (Same as other "RS" Camaro's)
ZL1 Dash Emblem - Dash ZL1 emblem only part of trim piece applique - 22967691
Camaro Emblem - 22752666 (Same as other Camaro's)
ZL1 Rear Bumper - 22894196
ZL1 Rear Valence - 22894221
ZL1 Rear Fascia Splash Shields - LH - 22895337 / RH-22895336
ZL1 Exhaust Tips - Not Available Separately- Must Buy Complete"CAT-BACK" SYSTEM - 22874269
ZL1 Exhaust Heat Shields - LH - 20957053 / RH - 20957052
ZL1 Rear Diff Housing - 22860925 (This is an empty housing-NO internals)
ZL1 Gears A/M 3.23 / 3.73 - 3.23 - 22835277 / 3.73 - 22835278 (Ring and pinion gears only)
ZL1 Complete Differential Asm. w/Internals - 3.23 - 20931134 / 3.73 - 20931133
Front Seat Cover Driver Bottom - 20996226
Front Seat Cover Driver Back - 22795649
Front Seat Cover Passenger Bottom - 20996215
Front Seat Cover Passenger Back - 22795669
Headrests (complete assemblies,no separate covers available) - LH/RH are the same - 20996228
Rear Seat Covers Bottom - 20996254
Rear Seat Covers Back - 20996242
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 03-05-2014, 09:14 PM   #5
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Is the rear lower control arm the only part that needs changed if going to the 1LE struts from stock 2011 SS?
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 03-05-2014, 09:53 PM   #6
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
i bought the front struts from my job separate from the track pack, so just see your local dealer.
2010 Camaro 2SS/RS LS3
TBD/TBD
K1 Forged Crank, K1 Forged rods, Diamond -15cc Pistons, .040 LS3 heads, Studs, Trunion upgrade, BTR valvetrain, Spartan LSX cam, Ported LS3 intake manifold, Ported 90mm TB, AGP 6262 Twins, Fore Innovations Triple pump, Flex Fuel, DW 1500cc, Mantic 9000, ZL1 short throw, DSS alum dirveshaft, DSS 1400hp axles, Strange S60 (3.54, S-trac), 1LE Shocks/Struts, Pfadt springs, BMR ZL sways, BMR LCA, Spohn Trailing arms, Spohn Toe Rods, BMR subframe connecters, Pfadt Solid Subframe mounts, Forgestar CF5V, Weld S-71, Toyo R888, MT ET Street R
blake2010ss is offline   Reply With Quote
Old 03-09-2014, 12:26 AM   #7
OmniCamaro
US Veteran
OmniCamaro's Avatar
Ok, to make it easier on us that want to change to the 1LE suspension: Can we just buy the struts (front &rear) and throw them on a 2010/2011SS? What EXACTLY is needed for just the basic upgrade (struts, shocks)?
I want to put the 1LE struts/shocks on my 2011SS.
Forgive me if it sounds like I have no clue, because I don't. Well, some clues, but not enough to figure this out on my own. Obviously.
THANKS!
Old 03-09-2014, 03:10 AM   #8
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
I sent a pm to Maureen and Rodgers on 1LE parts yesterday . They always got good deals and free shipping and handling . Expect to hear summtin on Monday
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 03-09-2014, 08:45 AM   #9
Synner
Drives: 2011 2SS/RS M6
You need shocks to replace shocks. Then an alignment. Thats it.
Old 03-10-2014, 02:44 PM   #10
OmniCamaro
US Veteran
OmniCamaro's Avatar
So the front struts are the same and the rear shocks connect the same? These are the 2 things I thought were different.
Old 03-10-2014, 04:53 PM   #11
Synner
The 1LE has a slightly different bushing in the shock mount but they both mount the same and I noticed zero difference in deflection when I tried them. There is no reason to upgrade the mount, personally I think I wasted my money getting them and I track the piss out of my car. All you need is shocks.
Old 03-10-2014, 06:09 PM   #12
OmniCamaro
US Veteran
OmniCamaro's Avatar
You wouldn't happen to have the part numbers would you?
Thanks for the help! It's much appreciated!!
Old 03-10-2014, 06:31 PM   #13
Synner
All the part numbers are up above in this thread.
