Solo Performance
Old 11-10-2013, 06:59 PM   #1
Mikes12ZL1
Drives: 2012 ZL1 Victory Red
Just bought 12 ZL1 looking to get 650 Rwhp HELP!!
I just bought a 12 ZL1 and I need opinions on the best and most reliable way to get 650 Rwhp. My car is bone stock!! My budget is 2500.any suggestions??
Mikes12ZL1 is offline   Reply With Quote
Old 11-10-2013, 07:24 PM   #2
Kmax
Kmax's Avatar
Drives: 2012 ZL1 125HP kit , EIBACH springs
Good luck with that. The budget is small for that kind of RWHP. 100 extra RWHP will run just over 3K.
Kmax is offline   Reply With Quote
Old 11-10-2013, 08:00 PM   #3
AbsolutHank
AbsolutHank's Avatar
Drives: 2016 Corvette Z06 M6
You'll have to wait it out for some used parts (headers, injectors, CAI) on that budget
2016 Corvette Z06 - Laguna Blue M6 IG:@absoluthank
Procharger F1A : 20/21 Vossen M-X1 3pc Wheels : Stage lll Aero : Kooks/E85 : 770whp
AbsolutHank is offline   Reply With Quote
Old 11-10-2013, 08:25 PM   #4
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Where is Asheville? Location might make a difference.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-10-2013, 08:45 PM   #5
Mikes12ZL1
What kind of power increase should I expect from these upgrades. Roto fab cai, headers,and blower pulley (18%)?
Old 11-10-2013, 08:50 PM   #6
cam99
cam99's Avatar
Drives: 2012 ZL1
you will need injectors with those mods also. Guessing 100-125rwhp.
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 11-10-2013, 09:00 PM   #7
Mikes12ZL1
So with those mods maybe 600-625 rwhp?
Old 11-10-2013, 09:17 PM   #8
cal45
cal45's Avatar
Drives: 2015 Blue Velvet Metallic ZL1
Read this thread
http://www.camaro5.com/forums/showthread.php?t=327383
cal45 is offline   Reply With Quote
Old 11-10-2013, 09:29 PM   #9
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
JRE 75-150 RWHP....
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 11-10-2013, 10:15 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
my .02
cai $400
Lower pulley 9.55 $600
ID850's $800
tune $400
i would do longtubes and tb as well but you 2500 budget is a bit light.
that will get you in the ballpark. HP goals are kind of wierd. a 625hp car will spank a 650 HP car that is setup better. IE cooling mods, better tire etc.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 11-11-2013, 02:01 AM   #11
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
you wont be able to get those kind of numbers with onlt 2500 bucks,sorry plus if you wanting to keep the IAT down you really need to get a bigger heat exchanger,and that alone for a good one is 700 to 999,,without paying to install it if you cant do it yourself
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 11-11-2013, 03:24 AM   #12
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Get a loan.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 11-11-2013, 07:07 AM   #13
Drew P
Drew P's Avatar
Drives: Camaro ZL1
If you have an AUTO (not manual), and you are not doing the install work yourself, expect to spend around 10k for 650 to the wheels reliably. You could get there for less, but prob not consistent or reliable.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion.
Drew P is offline   Reply With Quote
Old 11-11-2013, 09:21 AM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
Originally Posted by LuckyZL-1 View Post
Get a loan.
lol..
'17 ZL1 A10 Mosaic Black PDR/Nav 2:07.59 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
