Old 11-10-2013, 08:36 PM   #1
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Can I get your opinions on these?
My car is currently lowered on pedders springs and I'm going to be installing the pedders zl1 rear sway conversion and wanted to get some camber bolts to dial in my alignment right the first time. I was going to buy the pedders bolts but recently found these. What do you guys think?
http://ohio-speed.com/p-6037-2010-20...kit-87430.aspx
Old 11-12-2013, 12:11 PM   #2
lscamaro
lscamaro's Avatar
Bump
Old 11-12-2013, 04:53 PM   #3
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
The big difference I see is the Pedders kit looks like a stronger material and the adjustment side is welded - so not relying on the slot. Seems like dialing in the alignment would be easier on the Pedders, plus they have a 2nd locking nut too.
It might be why they're discounted so much possibly.
If you're considering caster adjustment for the front end, it's cheaper to buy the full alignment kit now - but you'll want the Pedder's front radius rod bushing (best ones for this part IMO). I didn't like the Pfadt front sphericals.... very noisy, popping sounds and wear out too easy.
LPE Brotherhood
Old 11-12-2013, 07:45 PM   #4
lscamaro
lscamaro's Avatar
Those are all great points, hadn't really thought about that. Makes sense. Might have to go with the pedders then. Even though their quite a bit more. I only need camber bolts so that's what I'll be buying. I'm definitely doing the Pedder's radius rod bushings because I'll be doing their Street Z Kit in the near future.
Old 11-27-2013, 02:43 PM   #5
lscamaro
lscamaro's Avatar
bump anyone else have any input?
