BORLA
Old 11-11-2013, 11:28 AM   #1
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
code p1074 ideas?
Okay I have a new engine with about 200 miles on it in my car, I picked it up from ADM to put some more break-in miles on it while Andy is on vacation. It ran great when I picked it up and I put about 60 miles on it with it running fine. Then it starts running rough and shows code 1074 left side O2 sensor showing lean. All of the fuel injector wiring connections seem to be plugged in and I changed the front O2 sensor. Changing the sensor seemed to make a little difference but did not fix the problem. The check engine light is not on in the dash but the code comes back in the computer even though I reset it out. I could just wait for Andy to get back but I like to think I'm not totally helpless mechanically. Any ideas?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-11-2013, 12:17 PM   #2
3monkeys
3monkeys's Avatar
My knee jerk reaction is a vaccume leak...
3monkeys is offline   Reply With Quote
Old 11-11-2013, 03:53 PM   #3
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
99% of the time everyone changes the sensor,without it fixing the issue..want you need to do is add a little propane to see if the o2 sensor changes trim,goes rich,then back to lean,that way you know its working..after that use a can of brake clean,make sure its the friendly type so it wont leave any nasty color changes on anything,look at the reading on your scanner to see if it goes rich,and listen for a change in rpm,when you here the rpm change,and the readings go rich,you will find your vac leak !!!
also you can look at your injectors if you have a injector light plug it in to see if the computer is commanding on/off, after that use a scope and place it on each injector to see if you hear the injector working !!! that should help you track down the issue,good luck let me know if i can help you in anyway ! I turn a wrench on and off for 20yrs before being wheelchair bound !!
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 11-11-2013, 04:39 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
P0174 or P1074?
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
Old 11-11-2013, 04:44 PM   #5
Stephen12ZL1
Drives: '17 ZL1 A10
intake leak, vacuum leak, pcv...basically any "phantom" air leak. Even an exhaust leak near the 02 sensor can do it.
Old 11-11-2013, 05:59 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Any ideas where I could have a vacuum leak suddenly appear, that was not there originally.
Originally Posted by Stephen12ZL1 View Post
P0174 or P1074?
My reader says P1074 but the I have seen that other readers transpose the first 2 digits.
I think this is a little deeper than I care to go myself at this time.....
I just had a revelation. Andy swapped my blower because it was making more noise than it should have been and I know the 2.3 blower he swapped on my car had been plumbed for nitrous. If I can figure out the Nitrous plumbing I'm sure I'll find a vacuum leak.
Thanks for all of the help guys!
Old 11-11-2013, 06:13 PM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Where would you inject nitrous on one of these beasts...lol? I'm thinking in the intake right in front of the heads but I really have no idea....
Old 11-12-2013, 07:20 AM   #8
Sugar's ZL1
Ron and Sugar
Sugar's ZL1's Avatar
Drives: 2013 Black ZL1 Vert A6
Hi Jess,
Just take it back to Andy and get some nitrous bottles. Use them for the strip!
I Love My 08 Pek a Poo
Sugar's ZL1 is offline   Reply With Quote
Old 11-12-2013, 08:18 AM   #9
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
I believe that the nitrous guys that use Andy's setup use that "bar" setup underneath the blower. I saw one at his shop but it works on the pressure side not the vacuum side. I would get a flashlight and check all hose connectors if I were you I've done it before on a friends car and we found one that wasn't seated all the the way. Goodluck!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 11-12-2013, 08:33 AM   #10
mylftft
mylftft's Avatar
Drives: 2013 TT ZL1
The 1.9 blowers have a machined direct port bar system, the 2.3 blowers run a dry shot into the intake tube before the throttle body. I guarantee its not caused from the blower or the nitrous system that was plumbed into a different intake tube.
mylftft is offline   Reply With Quote
Old 11-12-2013, 08:58 AM   #11
Stephen12ZL1
Drives: '17 ZL1 A10
easy trick....while the car is idling, take a can of intake/carb cleaner and spray gently near vacuum lines or intake area and see if the idle speed rises or surges. You can find any phantom air leak this way.
Old 11-12-2013, 10:25 AM   #12
jessrayo
Speed Freak
jessrayo's Avatar
You got this right, there is absolutely no sign of any changes to the blower or manifold on the 2.3.
I spent 2 hours last night tugging on hoses and wires and shining lights and clearing codes and got no where...lol. But we do think alike....lol.
I guess it is time to spray.... so far I have suggestions for brake fluid and carb cleaner, both dissipate well and clean, I don't know which would have a more dramatic effect on engine idle, perhaps ether starting fluid would work also.... It is probably the main ingredient in both of those cleaners.
Originally Posted by Sugar's ZL1 View Post
Hi Jess,
This car is already pretty scarey... but I like the idea.....
Old 11-12-2013, 01:39 PM   #13
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
Spraying the area usually works to find a vacuum leak. It just takes a bit of time in locating it. Or just wait until Andy returns, which probably will feel like forever.
ZL1-V is offline   Reply With Quote
Old 11-16-2013, 08:36 AM   #14
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Just hit land , Jess get the car back down will see
What changed .
The blower head units were identical with one swapped
And new gaskets were used and riveted I place correctly.
Our nitrous spraybar is in the INTERCOOLER top on the ZR1 lids.
Jess has his same lid.
ADM PERFORMANCE is offline   Reply With Quote
