Old 11-11-2013, 03:50 PM   #1
cal45
cal45's Avatar
Drives: 2015 Blue Velvet Metallic ZL1
Bone stock 2014 RWHP/TQ ?
I'm looking into buying a new 2014 ZL1 sometime in the Summer/early Fall. I've been reading up here and it seems most folks add something to their ZL1 (CAI, TB, headers, ...) so all the listed Dyno numbers have a wide range. Anyone have what the bone stock RWHP/TQ would be for a 2014 Automatic ZL1?
Thanks in advance.
cal45 is offline   Reply With Quote
Old 11-11-2013, 04:05 PM   #2
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
same as all the other yrs,mid 450's depending on dyno type..
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 11-11-2013, 04:28 PM   #3
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
my manual dynoed 499 bone stock
joes407 is offline   Reply With Quote
Old 11-11-2013, 04:55 PM   #4
cal45
cal45's Avatar
That sounds more in the ball park.
The crank HP is 580 and the parasitic loss on an auto is more than a stick, but most say it is a 15-18% power loss from the crank for an auto. Doing the math puts the RWHP for an auto in the 493 (15%) - 476 (18%) range. Just looking to see where the bone stock auto's actually landed at.
Old 11-11-2013, 05:08 PM   #5
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
About 475 with auto, look at the dyno thread. Many of the cars save baseline.
http://www.camaro5.com/forums/showthread.php?t=314663
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, ADM trunk intercooler reservoir & EMP pump, Ron Davis S/C heat ex, and radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1200+... 203.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-11-2013, 07:31 PM   #6
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Don't know about the torque, but I've always seen hp at 490-515 stock, depending on situations or dyno.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 11-11-2013, 07:53 PM   #7
gen=5
gen=5's Avatar
It depends on the car ( being a A6) as well as the dyno setting as in this pull its already got bolt parts and the reading was 479,which means that @475 stock a TB and rotofab are only worth 4rwhp,which makes no sense !!!
Yes there is also another pull that claims stock with 479RWHP
my car pulled 459rwhp completely stock which is about what this car was most likely at if it pulled 479 with a CAI,& a TB and a stock tune.. I think that a lot of dyno's are set really high,I would rather go to a shop that sets it dnyo low at the closest to the real numbers..we all have seen a car say 500rwhp on a DYNO then go to another and pull 450rwhp happens all the time...so to be fair its from low 450's to high 470's depending on the person thats setting up the dyno....Anyway the dyno is just a tool and it doesnt really matter what your car pulls to start with as long as its used just as a tool to tune,and compare A to B..I would be happy with a ZL that has 500rwhp and ran ten's than one that had 800RWHp and ran 11's if you know what I mean..
We all saw the write up's and the pulls on youtube claiming that their ZL1 pulled 525 to 535rwhp If you buy a ZL1 the dnyo numbers arent that important,its the gains from the parts you get that counts !!! GOOD LUCK
From the above thread
PFADT Tri-Y Headers & Cats installed with tune by Late Model Racecraft in Houston.
Auto Trans.
Dynojet
Hard break in
3,800 miles on the car
Baseline run is with stock tune and Roto-Fab intake & ported LSA TB.
Numbers are a bit low but it sure pulls harder and sounds a lot better.
Baseline (intake/tb/stock tune): 479/464
Headers/Cats/tune: 511/475
This image has been resized. Click this bar to view the full image. The original image is sized 1400x850.
Automotive youtube channel. / My First Autocross / My automotive blog / Build Thread
Old 11-12-2013, 06:44 PM   #8
cal45
cal45's Avatar
Appreciate the comments. Read thru the Dyno thread and it does look like base line, bone stock auto is in the 460-480 RWHP range. Right now, this is fine for me as I am looking to buy new next year and wanted something that was close to what my supercharged 2003 Vette produced (480 RWHP/ 424TQ) as it was a fun driver. Eventually, I will probably do the CAI, TB, long tube headers, and tune route....but not right away.
Old 11-12-2013, 08:25 PM   #9
jessrayo
Speed Freak
jessrayo's Avatar
I think this is supposed to be a rhetorical statement but it is pretty close to reality for me. I like the 800hp better. And it is pretty hard to run in the 10's when you smoke the tires at will through the first 3 gears. It doesn't matter how much power you have if you cant get traction. Has anyone made a 10 sec pass with just 500 whp? Just curious.
I get your point, fast is fast no matter what the dyno says. And as has been mentioned, there is a lot of variation between dynos.
Old 11-12-2013, 08:42 PM   #10
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Yeah that's my car. I was a little surprised how low the numbers were. I do plan on going to another dyno just to see if the numbers change much. What IS important is that I gain over 30 rwhp with headers and tune. So like you said, it is a tool. I wish I would have done a pull when I was completely stock because I either got a bum engine or the dyno reads a little low.
BaylorCamaro is offline   Reply With Quote
Old 11-12-2013, 09:04 PM   #11
13ZL1BLove
Drives: 2013 Camaro ZL1
My 2013 ZL1 M6 dynoed bone stock at 505rwhp
2013 Summit White ZL1
13ZL1BLove is offline   Reply With Quote
Old 11-13-2013, 06:15 PM   #12
SPOOKYGUNNER
ROCK
SPOOKYGUNNER's Avatar
Drives: 2013 ZL-1 TRIPLE BLACK VERT
MY 2013 A6 VERT DYNOED AT 494RWHP AT A MILE HIGH HERE IN DENVER.
SINCE THEN I ADDED S JANETTY RACING 75 RWHP KIT. DYNO WITHOUT A TUNE CAME IN AT 566RWHP.
I AM HAPPY AND DON'T NEED MUCH MORE HP OT TQ. IN THE COMING MONTHS.
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
SPOOKYGUNNER is offline   Reply With Quote
