Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 11-13-2013, 08:26 PM   #1
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
Arrow HAWK BRAKE PADS Huge Selection FREE S/H
Ohio Speed carries a large selection of Hawk Brake Pads (31 sets).
Our prices are the lowest on c5!
Free s/h on every order!
DON'T FORGET STAINLESS STEEL BRAKE LINES
(large selection of brake rotors also)
PM for our prices!
How to bed your pads
Bedding brake pads has a couple of important effects. The friction material in semi-metallic pads is held together by an organic binder, usually a type of phenolic material. As the pads get hot, the binder boils and burns from the top surface of the pad. Once this burning or “Bedding” takes place, the friction material makes proper contact with the rotor.
SPORT-TOURING, just as with all pad types, benefit from being properly mated to the rotor surface. If both the rotor and pad are new and the rotor surfaces are un-plated, it is most desirable to run the pads through normal commuting type driving for at least 150-200-miles before using them aggressively. If the new rotor surface finish is plated or the rotor is used with a compound other than the SPORT-TOURING ceramic-based pad, increase the commuter type driving with no hard use, to a total of 250-300-miles to accomplish the blending of the pad surface to the rotor surface.
Bedding The Pads - NEVER DRAG the brakes
Note: Never “Bed” pads on rotors, which have not first been “Seasoned.” Always allow a substantial coast down zone when bedding pads that will allow you to safely drive the car to a stop in the event of fade.
Perform four-repeated light to medium stops, from 65 to 10 mph, to bring the rotors to temperature.
Perform three light stops in succession. Perform eight heavy stops, back to back, at a point just pending wheel lock, from 65 mph to about 5 mph.
Drive for ten minutes to create cooling airflow, without using the brakes if at all possible.
to about 5 mph.
Additional Notes:
Metallic brake pads – Metallic pads need high temperatures to keep the pad “Bedded”. If you drive the car for a period of time without using the brakes extensively, you may need to “Bed” the pads again. This is not a problem. Simply repeat the procedure.
Switching from Carbon Metallic pads to semi-metallic brake pads (not recommended) – When switching from Carbon Metallic pads to semi-metallic brake pads will need to wear through the layer of carbon that the PFC pads have deposited in the rotor surface. The new pads won’t grip well at all, until this layer of carbon is removed.
Racers - Racers should “Bed” a few sets of pads at a time. In the event you need to change brake pads during a race, you MUST use a set of “Bedded” pads. Racing on “non-bedded” pads leads to a type of “fade” caused by the binding agents coming out of the pad too quickly. This is called “green fade”. These binders may create a liquid (actually a gas) layer between your pads and rotors. Liquids have a very poor coefficient of friction. This condition is the reason for reverse slotting or cross-drilling rotors, as it allows a pathway for the gasses to escape.
Ohio-Speed is your #1 Online Store for High Performance Parts and Show Car Accessories!
https://www.ohio-speed.com/default.aspx
TAKE ADVANTAGE OF OUR LAYAWAY PROGRAM!
OHIO SPEED is offline   Reply With Quote
Old 11-18-2013, 06:34 PM   #2
OHIO SPEED
OHIO SPEED's Avatar
HAWK Brake Pads on SALE with FREE S/H!
You won't beat our prices with free s/h!
Old 11-18-2013, 09:24 PM   #3
jvoisel
Drives: 2010 2SS/RS M6
Please PM me some options for my 2010 SS..
Looking for little/no dust and absolutely NO squeal. Thanks!
jvoisel is offline   Reply With Quote
Old 11-21-2013, 08:36 PM   #4
OHIO SPEED
OHIO SPEED's Avatar
We have the lowest prices on c5 with free s/h!
Old 11-24-2013, 04:09 PM   #5
OHIO SPEED
OHIO SPEED's Avatar
Nobody can beat our prices and FREE S/H!
Old 12-08-2013, 12:09 PM   #6
OHIO SPEED
OHIO SPEED's Avatar
Sale continues
Old 12-22-2013, 03:18 PM   #7
OHIO SPEED
OHIO SPEED's Avatar
Best prices on c5 with free s/h
brakes, camaro, hawk, stainless steel brake lines
