JUICEDMOTORSPORTS
View Poll Results: What to do about this squealing configuration?
Different pads 0 0%
Refund from Tirerack and buy tires/rims from somewhere that will stand behind their advice 0 0%
Exchange from tirerack (at no additional cost) tires/rims for a set that will fit with OEM brakes 0 0%
Pad re-work (different lube, more lube, etc) 1 100.00%
Voters: 1. You may not vote on this poll
Old 11-14-2013, 01:22 AM   #1
Kevlo79
Kevlo79's Avatar
Drives: 2012 45th Anniversary Camaro SS LS3
Exclamation Tirerack.com Akebono Brakes squealing
moved to wheels and tires talk.
Kevlo79 is offline   Reply With Quote
Old 11-14-2013, 02:54 AM   #2
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I done brake work for years at a Midas. Akebono makes pretty good stuff, double check the hardware and lube. Might even bevel the pads if they aren't already.
brakes, rims, squealing, tires
