Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Flowmaster Exhaust
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Suspension / Brakes / Chassis
Old 11-15-2013, 07:12 PM   #1
Drives: 2016 Camaro 2LT
PFADT GMPP Coilovers answer!
So......I found the answer. Not the same spring rates. More for street driving.
Yes! With our GMPP certification you can order our GMPP certified parts through your GM dealership. We've been working with GM on GMPP certification since they contacted us to collaborate with the GMPP/Pratt and Miller special edition SSX car.
Keep in mind there is a difference between the GMPP coilovers and our normal Camaro coilovers. After talking to GM about their goals with the SSX project, we decided to use a slightly lower spring rate which allowed for a more complaint ride on the street and to allow for more ride height adjustability.
Both coilover packages will give you an excellent base for a street/track Camaro, but the GMPP coilovers were designed with a little more street use in mind.
If you've got any questions please feel free to ask. Thanks!
PFADT RACE ENGINEERING 2010+ Chevy Camaro Adjustable Coil-Over Shock Kit - GM Performance Parts System
Part No. 1410125
Front Spring Rate 225 lbs.
Rear Spring Rate 450lbs.
chuckclanton is offline   Reply With Quote
