Old 11-19-2013, 12:43 AM   #1
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
Wheels/Tires
I currently have a 2012 LFX LT.
Here within the next couple months I'd like to replace the big bulky stock tires and get new rims. Most likely leaning towards the ZL1 replicas, unless I see something else.
My question is, is what size tires do you guys think work best?
Here's popular set ups I've read..
20x9 front, 20x10 rear
20x9 all corners
275 front, 305 (or) 315 rear.
Aside from looks, what will a wider rear tire give me? I'm assuming better traction but that's not a concern to me since I'm not pushing crazy HP.
My concern of a different size tire in the rear interfering with tire rotations.
Any suggestions? What are you guys who have aftermarket wheels running?
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 11-19-2013, 08:52 AM   #2
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
I have 245 set up in the front and 275 in the rear. It gives a good amount of traction and it is still has enough space to not rub. But I was being conservative. You can push (without raising your car) maybe until 305 in the rear ? but that is my opinion alone.
Current Car(s)
2015 Camaro 2SS 1LE 6.2L V8- Dream Car
2015 Equinox 2.4L I4- (Married Man with a kid ^__^)
Previous Cars
2013 Camaro 1LS 3.6L V6 - Traded
1995 Toyota Pickup 2.4L I4- Sold
1985 Mazda Rx-7 1.8L (Red) - Total Loss
1985 Mazda Rx-7 Turbo 1.8L Rotary ( White)- Sold
1996 Honda Accord 2.7L V6 - Wrecked
1998 Dodge Intrepid POS Engine- Lemon
rgrmoreira13 is offline   Reply With Quote
Old 11-19-2013, 09:35 AM   #3
KMPrenger
KMPrenger's Avatar
I went with the Factory Reproductions polished aluminum ZL1 replicas, 20x9 all around. Traction is important, but not really high on my list so I didn't need the widest option available. That said, you can run a 305 on a 9" rim, but for me I plan to run the stock 275s at all corners. For now I still have the stock tires, 275 rear and 245 front.
The 20x9s offer the biggest weight loss compared to the stock 20" wheels I had...although compared to your LT wheels there may not be much of a weight difference, but at least you won't be adding weight.
Also, the 20x9s have a nice aggressive offset which push the rims outward making for a nice looking setup compared to stock. I did the calculations, and the 20x10s in the rear only stuck out maybe a 1/4" or less further than the 9" wide rims...most of the additional width is inward, not outward.
Last but not least with the 9" all around and 275s you can rotate the tires if need be.
So thats my reasons for going with what I did. Of course if you want the 10" or even 11" in the back go for it, but in reality a 9" wide rim can accomidate tires that will provide more than enough traction for the V6.
Old 11-19-2013, 10:17 AM   #4
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I went with FR's 20x10 all the way around. P295/35/20 with the +23 offset. If you plan on lowering, you might want to go with +35 offset so you don't rub. I have adjustable supercars so I can get the right ride height. But I can rotate my tires all directions. Perfect set up. You go with +35 offset and you'd be set. Great for cornering. Great for all around driving.
Old 11-19-2013, 11:56 AM   #5
bionick
bionick's Avatar
Thanks for the info guys. I was thinking maybe
20x10/275 up front and 20x11/315 rear. Still deciding if I want all the same tires or use different sized in the back. Decisions!!
Old 11-19-2013, 12:48 PM   #6
bionick
bionick's Avatar
So you have 20x10 295 on all tires?
Old 11-19-2013, 01:36 PM   #7
Group-A Wheels
Drives: Camaro SS
20x9 all corners
As far as tire sizes go; on a car that is not lowered extreme the 275/315 combo is most ideal. It gives the best traction and cornering and maintains the correct rolling diameter. If your car is lowered cinsiderable we run 275/285-35-20 front and rear.
Either way the wider tire on the rear looks better and helps performance.
The only issue you have is the 10 is a touch narrow for a 315. It has been done before. But the Camaro really wants an 11 on the rear.
Group-A Wheels is offline   Reply With Quote
Old 11-19-2013, 01:43 PM   #8
bionick
bionick's Avatar
Thanks. Yeah I was leaving towards 20x10/275 up front and 20x11/315 rear, but my only concern is tire rotations. I do spin my tires a lot so tire rotations would be nice
Old 11-19-2013, 01:47 PM   #9
MrWray
SYBIL
MrWray's Avatar
Drives: 2013 2SS/RS, silver ice metallic
I have 20x9 on front with a 275 tire, and 20x11 on the rear with 315 tires, I love the way that it performs and looks
MrWray is offline   Reply With Quote
Old 11-19-2013, 11:56 PM   #10
bionick
bionick's Avatar
I do not plan on lowering. Should I get the 23 offset or 35 offset for front? I would be using a 275/20x10
Old 11-28-2013, 11:10 AM   #11
BRUKSHOT
BRUKSHOT's Avatar
Drives: 2013 Rally Yellow Camaro 1SS/RS M6
Interested in knowing this as well...
BRUKSHOT is offline   Reply With Quote
rims, wheel size, wheels and tires
