Anthony @ LG Motorsports
Old 11-19-2013, 09:24 AM   #1
ThePopo
Drives: 2010 Camaro
Swaybar size and stifness
Hey guys, I got a question. When running 10.5 rears how stiff should i go on the rear sway bar?There are a few bars out with various stiffness profiles. I got SS rims, springs and struts.
ThePopo is offline   Reply With Quote
Old 11-19-2013, 06:00 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Upgrade your 2010 to the new rear sway position further out on the rear axles.
Provides more leverage and is standard on all new SS's. It will require new lower control arms (not terribly expen$ive) as well as the sawybar and endlinks.
If your car's a V6 with stock brakes, Pedder's is the only bar compatible with enuff clearance. If you have Brembo rear brakes you can go OE parts or other aftermarket brands.
Pedders sells a complete upgrade kit with the LCA's with upgraded bushing, swaybar, and endlinks that is s'posed to be night and day difference. I'm saving for it myself!
Old 11-21-2013, 04:12 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
I'd suggest going with some newer style FE4 control arms and the Pfadt ZL Spec sway bars. The benefit of this setup is that both the front and rear bars are adjustable, so no matter what tires you are running; staggered or square, you can dial them in for the right amount of over/understeer.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
