Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 07-17-2009, 09:49 AM   #1
carfansince73
carfansince73's Avatar
Drives: Carefully
Slight backfire/sputtering when decelerating
I haven't had a manual trans car for a long time. When I am coming to a stop with the car in gear and the clutch out, the car will backfire/sputter a little around say 10mph. It doesn't sound bad to me, but I was just wondering if anyone else was hearing this.
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! I wonder if the state would allow this vanity plate---> KISSMYSS
carfansince73 is offline   Reply With Quote
Old 07-17-2009, 10:02 AM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Does this happen all of the time or just when the engine / exhaust is cold?
Crowley
Crowley is offline   Reply With Quote
Old 07-17-2009, 10:03 AM   #3
Vash
Drives: 00 Blazer
Is that how you normally come to a stop or your just testing using the gears to slow you down? It should be clutch in when your decelerating unless you specifically want to use the tranny to help slow you down. And the backfire is probably normal. It would of tossed code (ck eng light etc) probably is something was wrong with the ignition.
Old 07-17-2009, 10:13 AM   #4
carfansince73
Drives: Carefully
Crowley
All the time really. It's not really loud by any means, but I can hear it inside.
Old 07-17-2009, 10:17 AM   #5
carfansince73
Drives: Carefully
I usually always leave it in gear when I know I'm going to come to a stop. I let the engine help slow me down, kind of like in an automatic where the engine helps slow you down until the torque converter unlocks at low speeds.
Yeah, no check engine lights either. I'd say it's normal, and it really doesn't bother me. Just wondering if anyone else heard it when decelerating in gear at low speeds.
Old 07-17-2009, 10:18 AM   #6
lnsjr1
Drives: 02'Z28 07'CTS 03'HD Fatboy
Its a LS thing , I have had 2 over a 6 year period. They all do it.
lnsjr1 is offline   Reply With Quote
Old 07-17-2009, 10:19 AM   #7
beowulf80
beowulf80's Avatar
Drives: 2010 2SS / RS MT, IBM
I've found the same thing, worse when the car is cold. As you said, this only happens with the clutch out, so you are basically engine braking.
The poping you are hearing is most likely the pressure build up inside the cylinder escaping into the exhaust. Its debateable if this is really bad for your engine; given the very low amounts of power I would doubt it. It is more common to use engine braking on diesel engines, which by the nature of the combustion process are made to handle much, much higher BMEP's. Nonetheless I find it semi-annoying, so more often than not I've been shifting it into neutral early and coasting it down. You'd be surprised how long you can coast with little to no loss in speed, plus it saves you some fuel.
Forgive me for linking Wikipedia, but its got a decent explanation:
http://en.wikipedia.org/wiki/Engine_braking
beowulf80 is offline   Reply With Quote
Old 07-17-2009, 10:40 AM   #8
nards444
nards444's Avatar
Drives: 1SS/RS Black
mine does the same.
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 07-17-2009, 10:58 AM   #9
BOBSS
BOBSS's Avatar
Drives: 2008 TBSS
I have ARH headers now with electric cutouts, you should hear this spit n pop
Of course it's in true stereo now, I love it. I think it's unburned fuel hitting the headers in the primaries. The car is running rich and with a tune it should improve. I hope it doesn't go away for good
2SS RJT 6MT
ARH/QTP/HAI/Tune/Empire Billet
BOBSS is offline   Reply With Quote
Old 07-17-2009, 11:42 AM   #10
carfansince73
Drives: Carefully
I was pretty sure it was normal and not bad in any way. Still good to hear others have it and are not worried either.
Like I said though, it's not a bad sound either.
Old 07-17-2009, 12:55 PM   #11
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
this is the extra fuel burning off and popping when you slow down.. . very normal.
Magnaflow Cat back / ROTO-FAB Intake / Whipple Kit / RDP Tune.
580hp - 650Tq
franknbeans is offline   Reply With Quote
Old 07-17-2009, 01:09 PM   #12
badkarma
badkarma's Avatar
Drives: 2010 SIM 2SS Camaro
Hope it's not bad for the engine, cuz I do it on purpose coming downhill in my subdivision so all the morons can hear and not back out in front of me.
Plus it scares prudish women and small children.
badkarma is offline   Reply With Quote
Old 07-17-2009, 01:25 PM   #13
djsnoflake
Faith Keeper
djsnoflake's Avatar
I have that sound, and I love it!
Mwahahahahaa!
I love that some of the exhaust vids showing up seem to amp it up a bit. I like to think of it as my Camaro showing its' dislike for other cars. Mostly those silly import boys.
Old 07-17-2009, 02:28 PM   #14
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
very normal its just the extra fuel and compression of the cylinders which is good for the engine because it actually helps clean it out some
Gentry78 is offline   Reply With Quote
Old 07-17-2009, 02:41 PM   #15
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Its normal and can be minimized by driving style...
When you completely get off the gas pedal and are decelling, the fuel management shuts off the injectors to save fuel and to help pass CAFE requirements. Tuning can add some fuel when the throttle is in this closed position to reduce the decell popping noise.
Driving style can reduce the popping too. While down shifting and decelling, try giving the engine some fuel with your right foot. The injectors come back on when the pedal is pushed and the engine's RPM can be matched to the decell situation to smooth things out.
#5 - 2010 2SS/RS MN6 ABM-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 07-17-2009, 02:51 PM   #16
CamaroHutch
CamaroHutch's Avatar
Drives: 2010 Camaro 2SS RJT
my LS3 does the same thing! I love that sound...
Ordered Jan 09
2SS RS RJT
Delivery?? 5/27/09 #10630
AFTERMARKET:
Hurst STS
Borla ATAK Catback
CamaroHutch is offline   Reply With Quote
Old 07-17-2009, 04:16 PM   #17
ffrcobra_65
That is just your car's way of telling you "why the F$%* are you slowing down?!!?"
Old 07-17-2009, 04:53 PM   #18
MerlinZero
Big Orange
MerlinZero's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
I hear it all the time. I love the overrun on this car... sounds sooooo beastly.
" First, there was darkness, Then, On March 16th, Scott said LET THERE BE CAMARO, and there was Camaro, and Scott saw that it was good. Camaro5 3:16"
VIN: 2G1FT1EWXA9120523
ETA 7/6/09 (Delivered 7/10/09)
MerlinZero is offline   Reply With Quote
Old 07-18-2009, 01:50 AM   #19
RuggZ
IM BAACK - ABM 2SS/Rs M6
RuggZ's Avatar
Drives: 2010 SS Camaro&00 Firehawk#534
Ah, yes. I call it 'the dragon spit'
you understand she must sound her call to intimidate 'the heard'
We are so lucky to have a car like this
Chevy Love
GM Rocks
~RuggZ~
2010 Camaro SS/Rs ABM M6 blk rally stripes Moonroof
1993 GMC Yukon GT -to run stuff over- Black Cherry/Grey
1999 Olds Aurora '152 db audio system' Bronzemist/lt Grey
2000 Pontiac Trans Am FIREHAWK #534 of 704 Blk/Blk
2007 Buick LaCrosse 3.8 run 4ever, work car
RuggZ is offline   Reply With Quote
Old 07-18-2009, 02:06 AM   #20
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: THRSS #2 / CGM#1
Slight?...
Dude..you GOT to hear mine!!!!!!
The build of THRSS #2
Old 07-18-2009, 02:07 AM   #21
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
i do it in the truck every now & then just for kicks & giggles. it's a normal thing, but i don't know why on earth you'd do it all the time. if you know you're coming to a stop, it's much easier on the car & saves gas to put in neutral & coast. also, one thing to remember - brake pads are much cheaper to replace than driveline components, so why put that extra stress on them if it ain't necessary? if you're coming to a turn at the track (or making ricer kids p*** themselves), it's a great idea to engine brake, but for driving to work, not so much. just my .02
Old 07-18-2009, 03:28 AM   #22
BOBSS
BOBSS's Avatar
Drives: 2008 TBSS
I wonder, with headers, if the popping, some of which can be pretty loud, would be picked up by the knock sensor(s), (assuming there is one) and retard the timing, thinking it's detonation...?
2SS RJT 6MT
Old 07-18-2009, 04:13 AM   #23
Gentry78
HOOK'EM
Gentry78's Avatar
wouldn't really matter he's coming to a stop
Old 07-18-2009, 06:16 AM   #24
CamaroHutch
Does it use extra gas? Does it really add strain to the drivetrain? I have owned many MT vehicles and used engine breaking on everyone. Never had an issue. I would assume its using the same amount of gas as at idle (but I honestly am not sure).... I mean, 18 wheelers do it all the time (they sort of have to, or they just lose their brakes)
Ordered Jan 09
2SS RS RJT
AFTERMARKET:
Hurst STS
Borla ATAK Catback
Slight "Rattling" Noise... any ideas? DDustiNN 5th Gen Camaro SS LS LT General Discussions 38 10-13-2009 05:36 PM
Squeaky Breaks and a Slight Drift? JayhawkSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 07-11-2009 10:28 AM
slight clunking noise on tranny/ drive train camarorick V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 06-17-2009 08:40 AM
