Old 11-19-2013, 05:14 PM   #1
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Talking A sneak peak at our newly designed BMR rear lower control arms!
The is our newly designed BMR non-adjustable lower control that will replace our current version and will take over as part number TCA028. These non-adjustable lower control arms will work with the 2010 to current Camaros and can be used with the earlier style rear sway bars or the FE4 style rear sway bars. Our current BMR adjustable lower control arms (TCA029) will see the same changes and keep the TCA029 part number. We are thinking that this change in design for our TCA028 and TCA029 BMR lower control arms will become active within the next 3-4 weeks. If you guys have any question or inquiries let me know.
Now for the good stuff, here is some pictures of the new style lower control arm.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
BMR Sales is offline
Old 11-19-2013, 06:47 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Why the design change?
shibbs is offline
Old 11-19-2013, 06:59 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
To accomodate the newer FE4+ suspensions on the 2012+ camaros.
blazzin1 is offline
Old 11-19-2013, 07:33 PM   #4
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Powder coat those black and send em my way and I'll test fit and give a review.
Bo White is online now
Old 11-19-2013, 07:33 PM   #5
ddck24
ddck24's Avatar
Drives: 2012 Camaro 2ss 45th M6
Are there big advantages in the extreme anti roll bar setup vs the new^^^^ 2012+ stock setup????
A little street, mostly drag racing
ddck24 is offline
Old 11-19-2013, 07:39 PM   #6
smokum
smokum's Avatar
Drives: 2010 2ssrs
The way its notched will this fit a 15 inch wheel?
smokum is offline
Old 11-19-2013, 07:54 PM   #7
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Not for 2010 or 2011's? Or would I need new sways and end links?
PAUL SS is offline
Old 11-19-2013, 09:03 PM   #8
grocerygetter
instigator
grocerygetter's Avatar
So on lowered car the adjustable could get camber back to 0 or a hair positive for drag racing launches?
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
grocerygetter is offline
Old 11-19-2013, 09:27 PM   #9
blazzin1
blazzin1's Avatar
The "Xtreme" anti-roll bar is more geared towards drag racing vs. the FE4 suspension. If you are more serious about drag racing, you'd probably be better off with the Xtreme.
They will fit 17's, but not 15's. Need the BMR Drag Race Conversion for that.
These will fit both styles of suspensions.
Yep!!!
blazzin1 is offline
Old 11-19-2013, 10:29 PM   #10
ddck24
ddck24's Avatar
Blazzin you're a fountain of knowledge!! Lol
Appreciate ya!! Bmr and weld need to put ya on the payroll!
ddck24 is offline
Old 11-19-2013, 10:32 PM   #11
blazzin1
blazzin1's Avatar
Hahahaha!!! Thanks!!! If you only knew how close to reality that statement really was......!!!!! (Sorry, inside joke!!!).
blazzin1 is offline
Old 11-20-2013, 09:37 AM   #12
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Is your car lowered at all? Actually our non-adjustable lower control arms (TCA028) are a little shorter than the factory lower control arms so if you are lowered a little and looking to get to 0 camber or maybe even a little positive you could do it with our more affordable non-adjustable lower control arms (TCA028).
Blazzin1 is definitely a good guy for us and we appreciate him choosing BMR for his suspension and chassis needs!
T.C. Davis
813-986-9302
Old 11-20-2013, 11:31 AM   #13
Camper
Banned
Drives: 10' 2SS LS3 M6
so thats why none of my bolts fit on my 15" conversion.. may i make the suggestion that you fit everything with it painted, so we dont have to die grind everything..
Camper is offline
Old 11-20-2013, 11:51 AM   #14
BMR Sales
BMR Sales's Avatar
Drives: Race Car
What parts did you have issues getting the bolts through?
All of our plates are CNC lasered so there shouldn't be any issues with bolt fitment. The only time we ever have had a bolt fitment issue with that kit is with the upper coil-over mount. Sometimes the welder will take it off the jig too soon and the sleeves that the bolts run through will tweak just a hair making it a little bit of a pain to get the bolt in. If you have any problems with any of our stuff all you have to do is give us a call and we would be more than happy to help you out. It is hard for us to fix an issue if we don't even know that a issue exist.
T.C. Davis
813-986-9302
