JDP Motorsports
Old 07-17-2009, 02:00 PM   #1
sooner25
Drives: 1985 Iroc Z, 2010 2SS/RS
Clayed, Zaino'd. streaks?!?!
Okay, I clayed the entire car and zaino'd it. when I pulled it out of the garage, there were a few streaks on the hood. I'm sure I just didn't get the Z6 wiped off all the way when I did it. Is there anything I can do or will I just need to start all over?
sooner25 is offline   Reply With Quote
Old 07-17-2009, 02:03 PM   #2
hb-rocks
hb-rocks's Avatar
Drives: Chevy
Z6 it off....!
hb-rocks is offline   Reply With Quote
Old 07-17-2009, 02:11 PM   #3
sooner25
Originally Posted by hb-rocks View Post
Z6 it off....!
sorry, I guess i should have said its under the z-5. I can't believe i missed it!
Old 07-17-2009, 02:13 PM   #4
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
do you have Z-AIO? or Z-PC?
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 07-17-2009, 02:15 PM   #5
sooner25
neither.
Old 07-17-2009, 02:23 PM   #6
hb-rocks
hb-rocks's Avatar
Drives: Chevy
might call the supplier you purchased from?
Might have an easy suggestion that could save you from re-doing the whole panel.
I know my biggest lesson was....put the stuff on super thin!
Guess you simply just missed wiping a spot off....dam!
Old 07-17-2009, 02:27 PM   #7
sooner25
That's exactly what I did. I did it in my garage, and I guess i just missed it without the natural sunlight. totally sucks!
Old 07-17-2009, 02:31 PM   #8
hb-rocks
hb-rocks's Avatar
Drives: Chevy
DO OVER!
just wash the hood with Dawn to strip the wax off ....Dry....then Z1 and Z5..
Old 07-17-2009, 02:37 PM   #9
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
Start by washing the car again. Use the Zaino car wash if you have it, or a good quality car wash. (Dawn will not remove Zaino. And I would advise against using it.)
If you've used too much polish, it will streak. But not to worry.
Washing should remove the streaks. If not, use some of the spray detailer to remove any streaking.
Ed
Moose is offline   Reply With Quote
Old 07-17-2009, 02:49 PM   #10
CRC
Gearhead & Detail Guru
CRC's Avatar
Drives: 03 Marauder
Sooner25 check your PM.
CRC is offline   Reply With Quote
Old 07-17-2009, 03:00 PM   #11
lnsjr1
Drives: 02'Z28 07'CTS 03'HD Fatboy
DO OVER!
Never use dish soap on any car paint......
lnsjr1 is offline   Reply With Quote
Old 07-17-2009, 03:20 PM   #12
hb-rocks
hb-rocks's Avatar
Drives: Chevy
Zaino's instructions suggest using Dawn dish soap!
http://www.zainostore.com/Merchant2/...Q&Store_Code=Z
Q: Ok, I just received my Zaino products. What should I do to my paint before applying my Zaino?
A: The first thing you should do is wash your vehicle thoroughly with Dawn (or comparable) dish soap to remove any wax, grease, and oil from your paint. Then, my recommendation is to use Z-18 ClayBar to remove any bonded surface contaminants such as rail dust, tree sap, bug marks, or hard water deposits from the paint before applying any of your Zaino products.Using Clay is optional, but it really does make a difference!!
Old 07-17-2009, 06:37 PM   #13
PsyDoc
Drives: Soon-to-be 1st Gen
You sure it's the Z6? If you do not use enough lubricant (e.g., spray detailer, water, or whatever), the clay bar will not slide smoothly and leave a little blemish of clay behind. Try going back over these spots with a clay bar with plenty of lubrication and see if they disappear.
PsyDoc is offline   Reply With Quote
Old 07-17-2009, 06:59 PM   #14
Moose
Moderator
Moose's Avatar
The only time you should use 'Dawn' is to remove old wax prior to applying Zaino.
PHOTOS! Just Finished - Zaino'd Camaro sav1 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 37 07-13-2009 06:26 PM
Pics of Zaino'd IBM/w White Strips CAMARO_MOW Camaro Photos | Spyshots | Video | Media Gallery 12 07-12-2009 10:30 PM
WKDFIRE all Zaino'd edog Camaro Photos | Spyshots | Video | Media Gallery 76 06-12-2009 06:42 PM
Finally Pics of My Zaino'd SIM Camaro Embalmer Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 34 06-12-2009 09:54 AM
