JUICEDMOTORSPORTS
Old 11-24-2013, 09:44 AM   #1
stt816
Drives: 2012 Black 2SS/RS M6
Shaky Steering Wheel
I have pfadt lowering springs and have the street custom alignment they recommend. Also just got new tires on my 20x9 front&rear (275/40/20 all around) Now at 55+mph the steering wheel is very shaky. What is the cause of this and how can I get it fixed? Thanks
stt816 is offline   Reply With Quote
Old 11-24-2013, 10:40 AM   #2
stt816
Originally Posted by 130R View Post
If you just got new tires, and assuming you didn't add wheel spacers, the balance is probably off. Take it back and have them rebalance the wheels.
thank you, no wheel spacers.... i felt it a little before i upgraded the tires but now i feel it even more. Couldn't be the alignment right?
Old 11-24-2013, 10:53 AM   #3
mako22
mako22's Avatar
Drives: 2017 HB 2SS
Did you have 20x8 on the front previously?
mako22 is offline   Reply With Quote
Old 11-24-2013, 10:58 AM   #4
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
I suspect tire balance, but did you give the tires time to warm up? The stock P Zeros tend to flat spot especially when its cold. Not sure what tires you are running now.
Mods: JRE 470 cam kit, Dynatech long tubes/hi-flo cats, SLP underdrive pulley, CAI intake/ADM scoop, Pfadt Stage 2 suspension, Hotchkiss strut tower brace, Proven Wicked tow hook and end links, DBA rotors, Melling oil pump, Katech timing chain/LS2 damper, some bloody knuckles, still in progress...
gotroost is offline   Reply With Quote
Old 11-25-2013, 11:24 AM   #5
stt816
I am running general g max's now. The highway ramp is about 5 minutes away from me so they should be warmed up by then
Old 11-26-2013, 12:34 PM   #6
mako22
mako22's Avatar
Drives: 2017 HB 2SS
Going to 9" wheels with 275's in the front should make no difference as long as they are properly balanced.
Wider tires would impact ride on roads with heavy truck traffic
