Old 11-25-2013, 07:27 AM   #1
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Coilovers
Thinking of getting a set.
What are the advantage to go with Coilover over lower springs?
FSP tuned: 377/389
Old 11-25-2013, 07:37 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Coil overs are on a different level. With lowering spring you have no control over ride height or dampening, with coil overs you can custom tune both of those things. This means a much better ride or performance than you will get out of lowering springs. There is usually a nice reduction in weight as well.
Old 11-25-2013, 07:42 AM   #3
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
So if I want coilovers I would need to change my lower springs back to stock ones?
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 11-25-2013, 07:46 AM   #4
Apex Motorsports
No. All of that hardware comes out of the car and is replaced. Coil overs have their own springs.
Old 11-25-2013, 08:53 AM   #5
RickRay
INJACC
RickRay's Avatar
I have to pay more attention to things
Old 11-25-2013, 09:24 AM   #6
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Like Chase said, complete adjustability is the big advantage. You can adjust ride height and dampening levels. If you get a "double-adjustable" coilover, you can adjust compression and rebound independently. Makes it real easy to make adjustments between road course, drag racing, and street set-ups!!! However you want it is just a few "clicks" away. Ride height adjustments take a little more work, but still pretty easy.
blazzin1 is offline   Reply With Quote
Old 11-25-2013, 11:03 AM   #7
amanc96
amanc96's Avatar
Drives: 2011 SIM 2SS/RS
For me, the biggest advantage was ride comfort. I had eibach lowering springs and stepped up to coilovers. Very happy i made the move.
amanc96 is offline   Reply With Quote
Old 11-26-2013, 02:18 PM   #8
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Ride comfort, adjustability in height and damping, and much better handling when setup right. Coilovers also give you the ability to corner balance. If it's in the budget, Coilovers are hands down the way to go; especially with the black Friday sales going.
Feel free to call, PM or email me anytime with questions!
Best regards,
Tyler
888-308-6007
Old 11-26-2013, 02:40 PM   #9
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
coilovers if in the budget for sure
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And DSE swaybars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 11-26-2013, 05:28 PM   #10
Aequitas & Veritas
Aequitas & Veritas's Avatar
Drives: 2010 Camaro 2LT RS, 2009 GTR
I had Eibach springs and I really liked how they made the car look and it felt stock ride wise. I stepped up to the Pedders Supercar Coilovers this weekend, and wow is there a difference, I would suggest Coilovers (any set) if you can afford them over springs. They make you feel so much more planted!
Aequitas & Veritas is offline   Reply With Quote
Old 11-26-2013, 05:39 PM   #11
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
Basically everything has been already mentioned in terms of benefits. Adjust ability in dampening, ride height as well, better overall quality, lesser weight, pretty much everything you can think of aside from the cost, is better in comparison to springs.
Just do your homework on which coilovers are the best out there. My allegiance is with KW, but that's because I came from a European scene since that's where I started from, but they are DAMN good coilovers.
ModBargains.com is offline   Reply With Quote
Old 11-26-2013, 05:39 PM   #12
AG1LE
AG1LE's Avatar
Drives: '14 1LE
I'm doing springs with the Pfadt stage III ZL spec kit as Phase 1 of my suspension upgrade, and am planning to do coilovers later due to the cost of $3000+ (including labor). In-case you can't afford to do it all at once (I can't), I've seen many people prioritize other suspension upgrades over coilovers as a starting point (i.e. sway bars, rear trailing rods, rear tie/toe rods, bushings, etc), even for track use.
AG1LE is offline   Reply With Quote
Old 11-26-2013, 05:49 PM   #13
nyrfan
Let's go Rangers!
nyrfan's Avatar
Coilovers
Thanks everyone. I have a full suspension it talks with Matt from FSP, including PFADT coilovers.
Couple of questions:
Will I be able to adjust the height at my leisure or will that have to be done by the shop.
If I can do it, is it hard?
And would I need to realign?
Sent from my 2SS/RS
FSP tuned: 377/389
Old 11-26-2013, 06:09 PM   #14
Aequitas & Veritas
Not sure on the Pfadt ones but generally, yes w/o a shop
If I can do it, is it hard? - nope won't be hard. Very easy since you just have to jack up the wheel then use the supplied wrenches and twist and repeat on all four corners. Dependany on the type of COs might have to take a bolt off the lca to twist it.
And would I need to realign? - nope (less you drastically change it)
