Old 11-28-2013, 10:38 AM   #29
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Originally Posted by caverman View Post
ADM Performance has a solid bushing as well. It hasn't been around as much but looks to be a nice piece and priced decently. Just an option to look into. He quoted me the full cradle bushing plus upper control arm bushings installed for about the price of a set of Pfadt full bushing.
http://www.admperformance.com/produc...63&product=258
Although inserts are a much easier install, if I were at your power level I would step up to the full bush. Just go ahead and get it done right the first time. I've been using Pedders cradle inserts for a couple years now and they've worked just fine for me but I'm only at about 415 rwhp.
But the Pfadt's are orange...
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 11-28-2013, 11:09 AM   #30
smokum
smokum's Avatar
Drives: 2010 2ssrs
I know the adm billet subframe bushings are high quality and precision machined. They are also have a black anodized finish. The adm website pics are just the reference pics. I have these with the rear upper arm carbon fiber composite mounts. Many guys in dfw that frequently visit adm performance seem to all upgrade to these. Many local drag racers i run with all have these in there cars and love them. Keeps rear end solid and keeps wheels straight under acceleration. I have seen the rear wheels flex forward on the dyno with high horsepower cars. About 1/2 - 3/4 of an inch. That puts a bad toe in and puts a severe bind on your car during acceleration. The combination of the two really keep it straight. If you already have some arms you will have a killer setup. Straight launches and no wheelhop.
smokum is offline   Reply With Quote
Old 11-28-2013, 12:02 PM   #31
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Originally Posted by TBone View Post
LS3,
You have a Bis @ss cam and you're worried about noise??
Look, get the full Pedders bushings Kit from JDP and be done with it. You will not be sorry.
If I knew you were looking for a toe rod I could have helped you out.
T.
Damn, I wish I had known! lol my Cam actually isn't big, it's a little on the smaller side, it's the Heads that got me close to 500rwhp But I get your point!
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 11-28-2013, 12:05 PM   #32
caverman
caverman's Avatar
Drives: '69 SS Convertible
Yep!!! I will probably have these on my car someday. Just juggling where my mod money goes.
Build Journal
Old 11-28-2013, 12:12 PM   #33
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
I would go with the solid subframe bushing sets. This will allow no movement at the anchor point, unlike polyurethane that still moves and delrin that has a limited life. Remember every single IRS Corvette that GM produced has solid anchor points for the cradle front and rear.
Pfadt Solid Subframe bushings in action with a ton of other Pfadt suspension pieces and Pfadt Race Engineering 4-1 2" Primary LT Headers
Matt @ FSP is offline   Reply With Quote
Old 11-28-2013, 01:57 PM   #34
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
What is the difference in the install of the full bush vs inserts?
BigBlock69RS is offline   Reply With Quote
Old 11-28-2013, 02:03 PM   #35
The Stig
knows 2 facts about ducks
The Stig's Avatar
Inserts you just drop into the OEM bushings, install takes however long it takes you to drop the cradle.
Full inserts you have to drop the cradle and then drill out the OEM bushings.
Click to view my build thread
Old 11-28-2013, 02:33 PM   #36
BigBlock69RS
Ed
Thanks for the claification, sounds like the full bushes are the way to go, long as you have the cradle down might as well go the rest of the way. Especially when the 1le permagrin package comes with them.
On my list of mods.
Old 11-28-2013, 02:43 PM   #37
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
On my list of mods.
They cost twice as much also then inserts but are worth it if hp is alot. For auto x at stock hp levels inserts work fine, you have to be able to tell if one or the other got you .100 better. I sure couldnt!
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/427 RW HP/TQ
VR Baron is online now   Reply With Quote
Old 11-28-2013, 02:44 PM   #38
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Doing cradle bushings is easy, just takes a little time. Its easy people. I done it on jack stands in the driveway with one jack.
Old 11-28-2013, 03:24 PM   #39
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
I was able to install the cradle inserts without even fully dropping the cradle, and that was with jackstands in the garage. There's no way I'd have been able to keep the cradle attached for the full bushings...
Old 11-28-2013, 04:34 PM   #40
Bo White
Bo White's Avatar
I didn't fully drop mine either for the full bushings. One jack, a Lowes propane torch and hand tools.
Old 11-30-2013, 11:07 PM   #41
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
If it's worth anything, go with the full sub-frame bushings. The price of the bushings is pricey, but at the end of the day, it's well worth it and you don't want to end up doing the job twice if you end up doing it down the road. I just did mine a few days ago and following the Pfadt directions with a few differences, it took a little more than 4-5 hours. Besides doing it on the ground I cut the inner metal bushings and beat the hell out of them until they came out. Not saying a torch and jack won't do the job, but I didn't research any other way of doing it.
For myself, I removed the exhaust, disconnected the driveshaft, disconnected the strut from the control arm, pulled the four 24mm bolts that hold the cradle up and everything dropped. Dropping the cradle and getting the bushings out are the worst part of doing the job. After that putting it all back together takes less than half the time of getting it out. It would also be a good time to do anything else you need to do while it's down.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 12-01-2013, 01:28 AM   #42
Bo White
Bo White's Avatar
I didn't undo the drive shaft.
