BORLA
Old 11-28-2013, 08:20 AM   #1
Neuf Cruz
Neuf Cruz's Avatar
Drives: 2011 LS Black on Black 6speed
Check engine light?
Happy Thanksgiving to all!
Yesterday my check engine light came on. I filled ties, checked and topped off oil, radiator reservoir. Not sure wha else to check. Lights still on. I do not have onstage so can't ask for diagnostic over Onstar. Bedes taking to dealer (I have tune) anyway to find out why? Code? Andy to reset light? Sorry or the stupid questions but nothing's open and need car.
Any help is greatly appreciated!
Roto-Fab CAI-Ported Throttle Body-Black Ice Isolator-Flow Master Axle Back-RX-Catch Can-Hurst Short Throw Shifter-Trifecta Tune\Ghost Cam
Phantom Billet Grill-Billet Fuel Door-Side Gills-Headlight Armor Black Out Kit-Zenik Rims-Lowering Springs-MGP Caliper Covers-Dome\Trunk\Footwell Lighting.
Neuf Cruz is offline   Reply With Quote
Old 11-28-2013, 08:22 AM   #2
Shortbus
Shortbus's Avatar
Drives: 88 IROC Z28
You could take it to any AutoZone store, they can read the codes. Probably have to wait until tomorrow though.
Shortbus is offline   Reply With Quote
Old 11-28-2013, 08:49 AM   #3
cownipples
Drives: Silver Ice SS
If you recently filled up with gas check to make sure your gas cap is on right, this happened to me and I got a check engine light, I took off my gas cap and put it back on and my check engine light went off after about 20 miles.
cownipples is offline   Reply With Quote
Old 11-28-2013, 09:34 AM   #4
Neuf Cruz
Neuf Cruz's Avatar
I just did! I will go check and cross fingers!
There is no way with my luck that this could be the solution!
Thanks
Old 11-28-2013, 09:56 AM   #5
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
If the light is steady on it's emission related, if it's flashing I would get it checked as soon as you can.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 11-28-2013, 10:11 AM   #6
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
If car is running fine you should have no problem. Usually if serious the car will go into limp mode for reduced performance. Yous can tell and the DIC should be giving a message.
I would leave the light on so tomorrow you can find out from a place with an OBD2 scanner like autozone. If its really buggin you and you have a few minutes disconnect the battery for about 20min to clear the flag. If you have an LLT then your tune is not detectable by anyone but you or your tuner.
For the holidays you should be asking for a OBD2 hardware. Loads of good Bluetooth and WiFi dongles you can use with a smart phone so its always available.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 11-28-2013, 10:30 AM   #7
Neuf Cruz
Neuf Cruz's Avatar
Gas cap was fine. Light still on. Cars does run fine. I will check at autozone tomorrow.
Thanks guys
Old 11-28-2013, 10:32 AM   #8
turboguy327
Banned
Drives: 2011 Chevy Camaro
Check engine light?
Originally Posted by DARK AGE 53 View Post
If the light is flashing then it emission related, if it's flashing you need to get it checked ASAP.
Not true. Emissions don't need to be checked ASAP and a Check engine light ONLY flashes for cylinder misfires and those should be checked soon but if misfires are detected usually the light will stay on after a a second misfire event anyway.
Leave the battery connected. Don't clear the code. Scan it to see what the code is then clear with the scanner. A battery pull will make it a pain for diag for a tech or you later. If yor car car into my shop after you have been playing with it we would let it sit until there is nothing else to do. And most shops are like this. When a customer plays and doesn't know what they are doing just makes it a pain.
turboguy327 is offline   Reply With Quote
Old 11-28-2013, 11:25 AM   #9
DARK AGE 53
Drives: 2010 SS
I forgot one important word in my reply, that's not. I'll correct that with better wording, thanks.
Old 11-28-2013, 11:26 AM   #10
Neuf Cruz
Neuf Cruz's Avatar
Good point. Not going to clear it. Car is running fine so one fully ok as I have to go to Thanksgiving.
Wait, ths could be a good excuse to get out of visiting bathe in laws!
Old 11-28-2013, 12:09 PM   #11
TooCool5
TooCool5's Avatar
Anybodies guess until you get the codes.
Old 11-28-2013, 02:55 PM   #12
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Buy yourself a scanner, they are cheap.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan coil overs, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Dynamat, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 11-28-2013, 06:43 PM   #13
Neuf Cruz
Neuf Cruz's Avatar
Where can I buy one? Any brand recommendation and cost? Is it universal so if i get another type or an SS will it still work. This might go on the X Mas list!
If i go by dealer, do i have to remove my tune or go in and remove ghost cam?
Old 11-28-2013, 06:53 PM   #14
Kawirocket674
Drives: 2013 Camaro SS
I f you have a tuner it should read codes as well. Most do. Plug in your tuner and read the code.
Kawirocket674 is offline   Reply With Quote
