sjm autoprod
Old 07-18-2009, 12:13 PM   #1
robsmack920
Drives: 2010 2SS #3894
Is the paint under warranty?
under my spoiler on the passenger side, under the spoiler my paint seems to be rubbing off. anyone else have this issue? and is that under warranty?
robsmack920 is offline   Reply With Quote
Old 07-18-2009, 01:46 PM   #2
thanxa
Drives: zr1
Regardless of what posters with good intentions tell you , you need to approach any GM dealer with warranty issues . " They did this or they refused to honor that " means nothing . Every issue is an individual case . I've been selling GM for 45 years as well as other brands like Ferrari and they all have their factory guidance that they must follow . If they discover it to be their fault they will honor the paint warranty , however if its brake fluid , or some other chemical that caused it , even without you witnessing it then all bets are off . Trucks drive on our roads with Pest control , pool chemicals , etc that may have easily caused this . Your dealer will know immediately and if its their fault they will get paid to paint it .
thanxa is offline   Reply With Quote
Old 07-18-2009, 01:48 PM   #3
Indpowr
Drives: Corvette C6
yes they should cover it.
Old 07-18-2009, 01:51 PM   #4
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I have the exact same issue in the same area. It's as if they painted the car with the spoiler already on and the paint didn't get in that one little crack. It should be covered as a factory defect, IMHO, because that could spread over time and then your whole trunk lid is peeling paint. It's just one of many little issues I keep finding with mine, in addition to the mis-aligned door & dash, driver seat clicking noises and the weather stripping coming loose behind both my rear windows. I'm gonna make a laundry list of these warranty issues for the first time I take the car back to the dealer for work.
fldrummer is offline   Reply With Quote
Old 07-18-2009, 02:03 PM   #5
robsmack920
well my case is, it looks like the paint wasn't dry when they put the spoiler on (i think) and the spoiler is rubbing the paint off somehow
Old 07-18-2009, 03:29 PM   #6
Hebe4
Hebe4's Avatar
Drives: 2010 Black 2SS/RS M6
You mean like this.
Hebe4 is offline   Reply With Quote
Old 07-18-2009, 03:33 PM   #7
robsmack920
BLAME CANADA!!!!!!!!!!!!!!!!!
Originally Posted by Hebe4 View Post
You mean like this.
Old 07-18-2009, 03:34 PM   #8
bobby35ny
bobby35ny's Avatar
Drives: 2017 ZL1 M6, bye 2013 ZL1, 2010 SS
Is the spoiler loose and maybe rubbing off the paint?
-bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 07-18-2009, 03:44 PM   #9
robsmack920
it's not loose at all, but it's taking the paint off somehow
-bobby
Old 07-18-2009, 05:17 PM   #10
bobby35ny
bobby35ny's Avatar
Remember, there is alot of downforce there, maybe retorque the spoiler?
-bobby
Old 07-18-2009, 05:50 PM   #11
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
I got a huge warranty with mine, I don't plan on modding it, might put a snazzy SS/RS badge on the inside, but that's it. Anyway, with my warranty it covered everything. If the paint is scratched they'll fix it or a dent, they'll fix it. (Has to be smaller than a credit card...)
But in your case, if it's something from the factory that messed it up, I don't see any reason why they wouldn't or couldn't cover it.
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
Old 07-18-2009, 06:23 PM   #12
Ranger 75
Ranger 75's Avatar
Drives: 2010 Camaro 2SS IBM
You mean like this.
I have the exact same problem with the weather strip on the rear window. looks just like yours. I have tried to fix it myself but have not found a compound that will work yet. It is very hot down here and does not seem to want to cure.
Ranger 75 is offline   Reply With Quote
Old 07-20-2009, 07:23 PM   #13
Hebe4
Hebe4's Avatar
I repaired mine with 3M 06385 tape adhesive and 06396EA Adhesion Promoter, cost $20. Other water proof tape adhesives may work as well.
Just install the new adhesive beside the old adhesive under the glass. You may need to double up on the tape so it is equal in thickness to the old.
Clean the vinyl seal contact surface with the Ad Promoter and press into place....careful, you only get one crack at it. The alternative would be: drop off to dealer for half a day and 20 sets of fingerprints on car.
Old 07-22-2009, 11:33 PM   #14
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
You mean like this.
I had that too. I just pushed it back in place and it hasn't come loose.
Li0nel1234 is offline   Reply With Quote
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 120 07-31-2016 06:37 PM
Your Warranty Rights The_Blur Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 75 10-19-2012 08:24 PM
Paint your own stripes? blackZbandit Cosmetics and Lighting Modification Discussions 44 09-18-2011 10:22 AM
Will the V6 have DBW or a good old fashioned cable throttle? theholycow Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 41 08-02-2009 09:25 PM
