Old 12-02-2013, 03:27 PM   #1
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Back at ECS....again
After many months of planning, researching, and asking the same question multiple times, I decided to go back to ECS for some upgrades. What really set my decision in motion was the fact that I bought new TSP - 260cc heads, and a certain sponsor, who's name I cannot reveal, but rhymes with Patt dangled a new, bigger, blower in front of my face. So, I decided to call ECS, who are such sweet talkers, and make arrangements to have the new heads put on and swap the blower to a YSi. Currently, my car has the NOVI 1500SL making 811rwhp/719rwtq @ 15.3 psi. After this install and tune, I have no idea where things will stand, but it should be fun to find out. Along with these being installed, I have also installed Pfadt solid sub-frame bushings, DBA drilled/slotted rotors, Hawk pads, Mantic 9000 twin clutch, LPE launch controller, and Hurst line-lock. I'm hoping to stay near the numbers I'm at now, but also interested to hear what others have to say. BTW, this is on a stock bottom end.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 12-02-2013, 03:31 PM   #2
Matt @ FSP
Matt @ FSP's Avatar
Damn those certain sponsors
Good luck man, ECS FTW!
Matt @ FSP is offline   Reply With Quote
Old 12-02-2013, 04:42 PM   #3
Unreal
Drives: 2006 Z06
Damn Patt.
Good luck. Will be interesting to see the differences. Ysi's are fun blowers. Any idea what pulley or how hard you are going to spin it?
Nick
Corvette Z06 -1200ish rwhp
Old 12-02-2013, 04:43 PM   #4
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Can't go wrong with ECS. They know their stuff. I would say if you plan to use that YSI to its potential, I would be prepared for a bottom end at some point.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 12-02-2013, 05:15 PM   #5
Chris82xx
Chris82xx's Avatar
Originally Posted by Unreal View Post
Damn Patt.
I know that they're switching me from a 8-rib setup to a 10-rib setup. As far as the pulley size, I believe they'll still use the same small pulley, but use the restrictor plate to control the boost. Going to the YSi will allow me to stay at my current power levels but without using so much boost.
811RWHP/719RWTQ
Old 12-02-2013, 05:26 PM   #6
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Good luck man should be interesting and you'll probably be past my stock bottom levels. There goes my record LOL. I sold my car before those sweet talkers could get me into something more haha.
Ugh makes me depressed thinking about making the time to finish my project.
VanquisherSS is offline   Reply With Quote
Old 12-02-2013, 05:31 PM   #7
Craig B
Craig B's Avatar
Drives: 2013 1LE
Good luck with your build. Your in good hands over @ ECS. Let us know how you make out when it's all done.
Craig B is offline   Reply With Quote
Old 12-02-2013, 05:34 PM   #8
Supercharged SS
Drives: 2010 Camaro
Originally Posted by Chris82xx View Post
After many months of planning, researching, and asking the same question multiple times, I decided to go back to ECS for some upgrades. What really set my decision in motion was the fact that I bought new TSP - 255 heads, and a certain sponsor, who's name I cannot reveal, but rhymes with Patt dangled a new, bigger, blower in front of my face. So, I decided to call ECS, who are such sweet talkers, and make arrangements to have the new heads put on and swap the blower to a YSi. Currently, my car has the NOVI 1500SL making 811rwhp/719rwtq @ 15.3 psi. After this install and tune, I have no idea where things will stand, but it should be fun to find out. Along with these being installed, I have also installed Pfadt solid sub-frame bushings, DBA drilled/slotted rotors, Hawk pads, Mantic 9000 twin clutch, LPE launch controller, and Hurst line-lock. I'm hoping to stay near the numbers I'm at now, but also interested to hear what others have to say. BTW, this is on a stock bottom end.
Damn Pat sold me a truck load of parts too last week. At least he hooks us up!!
To bad you didn't buy his built 419. Then you'd be all set.
Old 12-02-2013, 06:15 PM   #9
old motorhead
Drives: Maggie blown LS3 vette
How much more power do you expect to make at the same boost level? With the restrictor plate, I can see the boost coming in quicker, but just wondering about the top end.
old motorhead is offline   Reply With Quote
Old 12-02-2013, 06:29 PM   #10
Abrahams11SS
Drives: 2011 2SS Black-n-Orange
Here I was excited to break into the 600-700 hp club and the big boys are all flirting with 1000hp daily drivers.. unreal..
Patt has a way of convincing you to do things that are awesome.. he worked his magician tricks on me as well.. lol
Abrahams11SS is offline   Reply With Quote
Old 12-02-2013, 06:41 PM   #11
grocerygetter
instigator
grocerygetter's Avatar
all I know is the power I'm at now is more than enough to get me in trouble on the street. LOL
For the track...hellz yeah throw the power to it!
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 12-02-2013, 06:46 PM   #12
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Sweet, will be following along with this one....
Old 12-02-2013, 06:51 PM   #13
Chris82xx
Chris82xx's Avatar
I know, but at least I'm ready for a short block whenever I decide to pull the trigger. Everything on the car is setup and ready for it.
811RWHP/719RWTQ
Old 12-02-2013, 06:53 PM   #14
Chris82xx
Chris82xx's Avatar
If I was to stay at the same boost level, I will go well above the 850 mark. With the restrictor plate, I can run 1-2 lbs. less and make the same low to mid power range. I'll see a bigger spike in the upper power band. I don't beat on the car too much, but I would love to see at least 850 to the wheels.
811RWHP/719RWTQ
