Old 07-18-2009, 05:58 PM   #1
GLBL WMR
Booya
GLBL WMR's Avatar
Drives: Black 2010 2SS/RS
Moisture in Door?
I notice that if it rains at night and I come out to a dry car, I get in and roll my windows down, and find that when I roll them back up, there are streaks of water on the outside. It appears that the seal on the top of the door is not doing it's job. Anybody else have this problem?
2010 Camaro SS/RS RP6 | 2SS package, M6, black, black leather
2000 Blazer LS | winter beater
GLBL WMR is offline   Reply With Quote
Old 07-18-2009, 06:08 PM   #2
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Haven't had that problem but it also hasn't rained here in 2 months....
Old 07-18-2009, 06:14 PM   #3
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
That's because the seals are wet. The inside of the door is considered a wet environment. If you look under the door just inside of the door hemmed edge you will see drain holes that allow any water that does get inside the door to drain. If you were to take your door trim off, you would see a barrier that seals any water inside the door from getting inside your car.
The key is that the water does not get inside the car. So from what you've described, you door is working perfectly as designed.
I know this as I've been responsible for Front, Rear and Side Closures at various points in my career.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 07-19-2009, 09:35 AM   #4
GLBL WMR
Booya
GLBL WMR's Avatar
Good to know, Number 3. Thanks.
2010 Camaro Billet Aluminum Fuel Door - Installed! Heat Metal Cosmetics and Lighting Modification Discussions 41 08-13-2012 04:55 PM
anyone having this issue ? drivers door Damage from seat belt with pictures yesno20102ssblack Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 06-25-2009 12:51 PM
Camaro Custom Billet Fuel Door - Heat Metal Heat Metal Cosmetics and Lighting Modification Discussions 7 06-24-2009 05:27 PM
Another Fuel Door Question (Everyone read please) DJ ATOMIX Cosmetics and Lighting Modification Discussions 8 06-22-2009 01:23 PM
door protectors Lloyd LeBaron Cosmetics and Lighting Modification Discussions 6 06-20-2009 09:16 AM
