sjm autoprod
Old 07-18-2009, 07:46 PM   #1
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Exclamation HELP! Fuel line nut rusted, can't remove fuel filter
On my 2002 GMC, the fuel line nut is rusted to the fuel filter (or maybe to the line; probably both) and I can't free it. I've done lots of whacking with hammers, PB Blaster, Shimano penetrating oil, cold spray, and plenty of brute force.
I've gotten under and sprayed it with the Shimano stuff every day for a week. I just got the PB Blaster today.
I don't think I can reasonably heat it, nor grind off the filter's nut, since I'm working with fuel line.
Any other ideas? It's starting to look like I'll have to replace the fuel line. :(
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 07-18-2009, 08:07 PM   #2
shank0668
shank0668's Avatar
Drives: '00 WS6/'06 LJ/'76 Trans Am
Send a message via AIM to shank0668
Some great quotes in your Tags. Idk? Replacing fuel line sounds best.
Old 07-18-2009, 08:23 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
I think you are not using enough elbow grease. you are turning the nut the correct way and holding the other one still correct? (jw.)
I piss excellence
and fart awesomeness
Old 07-18-2009, 08:39 PM   #4
theholycow
theholycow's Avatar
Good thoughts. I am holding one and turning the other, and doing it all in the correct direction -- unless it's reverse threaded, but the new filter isn't so the parts store or Purolator would have had to make a mistake. I'm using plenty of elbow grease (so much that I'm afraid that even the flare wrench will round the nut).
I was able to remove the front/outbound connection, but the rear/inbound connection won't budge at all.
I'm posting on every forum I use, out of desparation...I did get one good suggestion on another forum: Since I may have to give up and declare that fuel line a loss, maybe I could remove said fuel line still attached to the filter and work on it while it's not attached to the truck. Then I could clear it of fuel and use heat.
Old 07-18-2009, 08:53 PM   #5
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
Let the penetrating oil sit on it for an hour or so. That should loosen it. I used Ballistol as a penetrant on my '02 Silverado fuel filter nut this year. Came right off.
patriotpa is offline   Reply With Quote
Old 07-18-2009, 08:57 PM   #6
CamaroSpike23
Truth Enforcer
you are reorienting yourself when you switched to the other side right?
I piss excellence
Old 07-18-2009, 09:02 PM   #7
theholycow
theholycow's Avatar
Yup, I am reorienting myself to make sure I'm turning stuff in the correct direction.
I've let the penetrating oil soak in repeatedly, daily for the last week. :(
Anyone know where I can look up my fuel line part number online and maybe order it? Rockauto.com doesn't seem to list it.
Old 07-18-2009, 09:05 PM   #8
CamaroSpike23
Truth Enforcer
www.gmpartsdirect.com
(and I believe they are offering a discount to Camaro5 members)
*edit* here it is...
http://www.camaro5.com/forums/showth...ighlight=parts
I piss excellence
Old 07-18-2009, 09:28 PM   #9
theholycow
theholycow's Avatar
Already checked gmpartsdirect.com - the fuel system parts categories they offer are:
Cap, Connector hose, Filler pipe, Fuel pocket, Fuel strainer, Fuel tank, Heat shield, Module, Pressure sensor, Seal, Sending unit, Strap
If I click "Connector hose", which is the closest to being a hard line in that list, it says No items were found in this catagory. A search for "fuel line" returns nothing.
I guess I have to wait for a dealer to be open. Damnit, I want instant gratification!
Old 07-18-2009, 09:34 PM   #10
Vash
Drives: 00 Blazer
Hit the local salvage yard. Might even be able to find an online salvage that has one.
Call your local junkyard and ask for the part with your vehicle info. They normally can tell you if they have the lines in stock.
Old 07-19-2009, 01:38 AM   #11
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
If it may be a loss anyway, why not try a medium size pair of Vise-Grips on the line nut, and the filter nut. A little impact from a hammer on the tool has worked for me.
They also make fuel line repair kits that may help.
http://www.summitracing.com/parts/RN...3/?image=large
They feature factory-style connections, so installation is easy. Available in a variety of sizes and styles, Dorman fuel line repair kits will replace broken, cracked, or damaged OEM fuel line connectors.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP Graduate, A.S. Automotive Technology, Telecommunications Specialist, CISCO Certified Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 07-19-2009, 07:49 AM   #12
theholycow
theholycow's Avatar
I'm not sure how vise-grips would help. My flare wrench has a good grip on the nut already and I've tried hitting it with a hammer.
I would consider the repair kit but I think it requires a few inches of straight line where it can be cut and spliced; my line has a bend right next to the filter. It looks just like the image that Spike posted above, and it's the left side of that image that I can't get undone.
In that image, the small nut is around the line and should turn freely of the line; the large nut is welded to the filter body. Unfortunately, you can't just crank the hell out of one nut; doing so will twist the whole assembly and break the line. You have to hold one nut and turn the other (or turn them against eachother).
I'm using proper flare wrenches:
which provide a good grip that won't slip or round the nut. I've managed to brace it against the frame in such a way that I can whack it with a hammer to make it turn and it didn't seem to get anywhere.
Old 07-19-2009, 07:51 AM   #13
steddy2112
steddy2112's Avatar
Drives: 2008 Cobalt SS
When you say you are using penetrating oil, I hope you are not using WD-30 :LOL:
steddy2112 is offline   Reply With Quote
Old 07-19-2009, 08:18 AM   #14
Vash
Drives: 00 Blazer
No he mentioned PB blaster, which is the best one imo, in his OP.
If that does not work no juice will. Either brute force or replace lines.
fuel, let go of my nuts, mah nutz, nuts
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
