Flowmaster Exhaust
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 03-21-2008, 10:49 PM   #1
TheClassicCarKid
TheClassicCarKid's Avatar
Drives: V45
First Gen. Z28's horsepower
How much power did those 302's REALLY put out?
All of the stang guys in one thread..wow..lol
TheClassicCarKid is offline   Reply With Quote
Old 03-21-2008, 11:11 PM   #2
SSmoked
SSmoked's Avatar
Drives: '12 Camaro ZL1 #1255
i rember talking to a guy at a car show with a z/28 with a 302 and he said 295hp with 295 torque.
SSmoked is offline   Reply With Quote
Old 03-21-2008, 11:17 PM   #3
smokn'
Drives: Banana boat
i've heard a lot higher numbers than that. try 400.
http://musclecars.howstuffworks.com/...camaro-z28.htm
smokn' is offline   Reply With Quote
Old 03-21-2008, 11:57 PM   #4
Z27
Z27's Avatar
Drives: 71 Camaro SS 00 Camaro SS
That would be about right. All the stories floating around back then were talking 390-400HP. They needed 4:56 or 4:88 gears to really make a showing. They liked to rev.
Z27 is offline   Reply With Quote
Old 03-23-2008, 12:27 AM   #5
COPO_Chevy
COPO_Chevy's Avatar
Drives: 2015 Malibu 1LT; '87 Grand Prix LE
Send a message via MSN to COPO_Chevy
ya...iv heard up to 435 hp...and ya they really did like to rev, most people back then could go pretty fast in there Z's. However, most couldnt get that fast becuz they didnt shift at the rit points...these 302's liked to rev. high and be shifted at a higher rpm. Most people didnt want to rev there engine up to the 7x rpm (i believe it was that high anyway..if i can remember my research rit..)that was needed. The Z's were very nice cars expecially with the cross ram and the 2x4 barrel carbs that were optional at dealerships
1969 Buick LeSabre --- Need to sell..
1987 Pontiac Grand Prix --- Project
2013 Chrysler 200 Touring--- Traded
2015 Chevy Malibu 1LT--- Daily Driver
________________ --- Reserved For Camaro
________________ --- Reserved For Classic Buick
COPO_Chevy is offline   Reply With Quote
Old 04-02-2008, 02:04 PM   #6
CaptianSam
Car Garage
CaptianSam's Avatar
Drives: 350z,A4,SRT8...see sig
im telling my dad to stroke the 302 and polish and install a new tach but he wont... hes all about ORIGINAL...
2012 2SS RS Ordered
Black on Black 6 speed Coupe Artic Lid Stripes
Yes I Supercharge Everything
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Current Autos:68z28,03viperSRT10,04escalade,05RangeRoverSport SC
Project Autos:80corvette350-500hp 6speed,06charger S'C 6-speed posi,74Firebird400blue,69chevelle572 707
New Autos:2012CamaroSSRS,09ChallengerSRT8
Past Autos:....too many to list
"i told you it was gettin' an LS3"
Go down deep enough into anything and you will find mathematics. Dean Schlicter
B.Sc. Hons. Mathematics
CaptianSam is offline   Reply With Quote
Old 05-26-2012, 06:40 AM   #7
DarrellJr
Drives: 68 camaro
The 302 in³ (5.4 L) V8 engine was only available in first-generation Z-28s (the 350 LT-1 was used in 2nd generation Z-28s), and was created in response to a Trans Am racing engine displacement limitation at that time of 5 litres (305ci). The 302 was created by installing a short-stroke 283ci engine crankshaft in a 327ci block, resulting in 302ci. This just fit the Trans Am limitation (the bores of the actual racing engines were tweaked to produce exactly 305ci) and this design (with special modifications for high-performance use) resulted in an unusual, high-revving engine that helped create the legend of the Z-28. The 302 was the only engine available in the first-generation Z-28.
Z28 302ci/290HP V8 4BC - Z-28 only
referance:http://www.firstgencamaro.com/engines.html
DarrellJr is offline   Reply With Quote
Old 05-26-2012, 07:11 AM   #8
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I had 2 - 1969 Z/28's, one with the original DZ 302's ( 4" bore, 3" stroke ) engine. That car also had factory optional 4.10 gears. The standard gear in the 1st gen Z/28 was 3.73 and I drove several with 3.73's and they weren't much fun to drive on the street. Chevy rated the '68 and '69 Z/28's at 290hp at the flywheel. In reality they were about 390hp and really didn't make any power until 4500 to 5000 rpm but would pull to just past 7000rpm. The 1970 LT-1 350 ( 4" bore, 3.48" stroke ) that was put in the '70 Z/28's and Corvettes was essentially the same engine as the '68 & '69 DZ 302 ( same heads, compression, cam, carb, intake manifold ) with 48 more cubes due to the longer stroke crank and had a ton more torque.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 05-29-2012, 09:48 PM   #9
macalot
macalot's Avatar
Drives: 1969 + 2015 Z/28s F250 SD
If I could only find a copy of my dyno results, I'd post it here. Needless to say at the rear wheels the dyno said 330 something HP. Stock motor with the original heads worked over and ported along with the intake. I installed 4.56 gears back in the mid '70s and have turned low 13's on regular ole street tires through the chambered exhaust. And the car is very consistent.
When running the car hard(which I don't do much anymore), 7,000 rpms is the shift point and I can tell you in 4th gear at 7 grand the engine is still pushing you back. The vast majority of races I've won over the years was on the last 300 feet of the 1/4 mile....the 302 doesn't know when to quit.
macalot is online now   Reply With Quote
Old 05-30-2012, 04:28 PM   #10
76z28
76z28's Avatar
Drives: 1976 camaro
302 in³=5.0L
76z28 is offline   Reply With Quote
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
If the El Camaro makes it to production.... Silverado General Automotive + Other Cars Discussion 8 02-21-2008 11:17 AM
Making Modern Horsepower the Old-Fashioned Way KILLER74Z28 General Automotive + Other Cars Discussion 14 02-02-2007 02:50 PM
