BORLA
Old 07-19-2009, 12:15 AM   #1
Icefsh
Icefsh's Avatar
Drives: CGM 2LT/RS M6
Octane Ratings?
Wondering what octane gas to put in my V6? Here in the mountian states the minimum regular gas is 85 octane, midgrade is 87, and premium is 91. When I go to states with lower elevation the octane is higher than here. What difference does elevation make? Did not notice any problem with 85 octane (only 1 tank of gas). But 87 octane seems to run better. Only 730 miles now.
Icefsh is offline   Reply With Quote
Old 07-19-2009, 12:25 AM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I think 87 is recommended, thats the standard minimum most places. If 87 runs better, use it. What is it, $2.00 more per fill up?
Old 07-24-2009, 02:09 AM   #3
fastal
Drives: 2010 2SS/RS, 2000 Z28
Stick with regular which for us is 85. Due to the altitude there is less oxygen so less potential energy to be made. Since the Denver area is a mile high we lose roughly 20% of the power the car would make at sea level.
I've got my 2LT/RS and have 1700 miles on it with mostly 85 octane and no problems. Unless you are getting pinging higher octane can cost you power.
fastal is offline   Reply With Quote
Old 07-24-2009, 01:56 PM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
The manual says 87 or better for the V6, 91 for the V8 ....
Old 07-24-2009, 01:59 PM   #5
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
The Chevron station I use has 93 so that's my place now...
Old 07-24-2009, 02:15 PM   #6
Bbrock25
Bbrock25's Avatar
Drives: 2010 1SS/RS Inferno Orange
yea like the good stuff is what .20 more per gallon on 19 gallons if you were dead out its only $3.80 more per fillup.
Bbrock25 is offline   Reply With Quote
Old 07-24-2009, 02:31 PM   #7
volleyfan
volleyfan's Avatar
Drives: 2003 Tahoe Z71, 2010 Camaro SS
85 in Colorado is equivalent to 87 at sea level. For cars that recommend 87 or better, 85 is acceptable at altitude. Same for the other octanes. If your car needs 93 or better, 91 is equivalent at altitude. Many people don't know this and waste their money buying mid grade or premium when they don't need it.
2SS IOM
1100 - 14 Apr 09
3800 - 16 Jun 09
6000 - 2 Jul 09
volleyfan is offline   Reply With Quote
Old 07-25-2009, 08:29 AM   #8
Icefsh
Icefsh's Avatar
Thanks for the input everyone. Have used 85 octane in all my other vehicles with no ping.
Old 07-25-2009, 08:51 AM   #9
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Actually... most modern cars have knock sensors that detect the ping before you can actually hear it and will adjust the timing (retard the timing) to stop the pinging...
scrming is offline   Reply With Quote
Old 07-25-2009, 10:00 PM   #10
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
+1 on the pinging. If you hear it, you've got problems. The V-6 has one sensor for each cylinder - very sophisto...
A small addition to what was said above regarding altitude: it's not just that there's less oxygen at higher altitudes, there's less atmospheric pressure. So compressing air/fuel mixtures at say 5000 feet altitude means that the effective compression ratio yields less cylinder pressure. A lower octane fuel is called for in that case and will work fine. Higher octane fuel would not burn completely and cause fouling and carbon deposits.
Please correct any misstatements above. I sell floorcovering and am not any real mechanic. But my bed is as comfortable as those at a Holiday Inn Express.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 03-08-2015, 01:04 PM   #11
ACE1109
Drives: 2015 Chevy Camaro
I've read that some people use 93 or 95 in the v6 and get better mileage than 87 or 89. Can you use 93? I have a 2015 camaro and was wondering if I should give 93 a try
ACE1109 is offline   Reply With Quote
Old 03-10-2015, 01:24 AM   #12
omgitsmiketuck
omgitsmiketuck's Avatar
Drives: 2011 Camaro LS (6-speed manual V6)
I ran "regular" which I think is 87 in az?... for a good 15...16k before I started running higher octane. These cars don't really need it unless you're highly upgraded or you have a tune. My car ran just fine with "regular" gas with mufflers and CAI intake w/ intake scoop. I got an IPF tune, so I have to run 91 now, but for average bolt on mods, you can run regs.
Vitesse Throttle Controller / Flowmaster 40 Mufflers / CAI Intake / Apex scoop and washer relocate / Epic Engineering Catch Can / SS Stoptech Brake lines / BMR 1.2" Lowering Springs / IPF tune /Magnaflow X-Pipe / 25mm Mace intake spacer / BBK Long Tube Headers with High Flow Cats
omgitsmiketuck is offline   Reply With Quote
Old 03-10-2015, 06:10 AM   #13
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
The V6 Camaro is set-up to run just fine on 87 octane, however it pulls timing while doing this too. Which robs you of the precious HP we are all craving.
Many of us run 93 octane to obtain every last HP and keep the timing at bay the best we can.
Octane Booster? MikeBing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 10-25-2009 07:08 PM
Anyone else using octane booster in their SS? OHIOSS 5th Gen Camaro SS LS LT General Discussions 27 07-08-2009 06:03 PM
91 octane? electlatino 5th Gen Camaro SS LS LT General Discussions 15 06-02-2009 05:18 PM
Question to current camaro owners - what octane you using? RoyalKev 5th Gen Camaro SS LS LT General Discussions 17 05-12-2009 06:01 PM
Octane Booster and synthetic oil big_bank5000 5th Gen Camaro SS LS LT General Discussions 25 05-14-2008 04:32 PM
