HURST
Old 12-09-2013, 02:47 PM   #1
NJBourne23
Master of Nothings
NJBourne23's Avatar
Drives: 2010 Chevy Camaro 2LT/RS
"S" mode rpm
is there a problem with driving in "S" mode all the time or most of the time? Next i ask, has anyone seen that rpm sit high at times if you hit the gas briefly and when the car finally comes down you get a decent breaking effect from the transmission? I hope that made sense because i'm not sure how else to explain it.
2010 Chevrolet Camaro 2LT/RS
NJBourne23 is offline   Reply With Quote
Old 12-09-2013, 03:14 PM   #2
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Nothing wrong with full-time Sport Mode - that's what I usually do if I'm not on a long highway cruise (then I just put it in Drive). All Sport Mode does is raise the shift points a little so, yes, it will shift at slightly higher RPMs - but that is what it is designed to do.
If you "hit the gas" enough for the tranny to kick into a lower gear then, yes, the RPMs will "sit high", just like it will in Drive. There is a decent engine braking effect in Sport vs. Drive - at least it seems to be. Haven't actually verified the RPM difference (if any) between the two.
Bottom line: If I'm going to be driving when it goes through the gears (city type driving), I'm always in Sport Mode. Personally, I believe it gets slightly better gas mileage in Sport Mode.
Mind you, I run a Range AFM Deactivator all the time as well so AFM never figures into the picture. Things will be different w/ AFM involved.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 12-09-2013, 03:30 PM   #3
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
There is no problem with driving around in S mode all of the time. Many members will only drive it in S mode.
My car was basically tuned to be in S mode all the time due to the mods I have. It is primarily a racing mode that tends to keep the RPM's at the higher level when you are flooring it because it is expecting that you are racing.
This may be totally un-related, but I broke a valve spring during one of these "Elevated RPM" incidents. Engine builder though said it was a very unusual/non-typical failure.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers with Trunion Bearing, ATI Balancer/keyed, AR Headers/Borla Catback Exhaust, DSS 1400 HP Axles, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)with Hidden Lightweight Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 12-09-2013, 06:46 PM   #4
PalmerGA
PalmerGA's Avatar
You don't have to be "flooring it". The actual shift points are higher (yes, based primarily on RPM) whether you are at WOT or just normal driving. Naturally though, the more you are into it, the longer it holds in each gear.
Old 12-09-2013, 07:04 PM   #5
aj0294
Drives: 2010 Camaro 2SS/RS
being that we're on the topic, is it normal for S mode to hold 3rd or 4th gear when doing a hard acceleration? (well harder than normal). I was pulling out into traffic but had to accelerate a little quicker. Once i got off the gas, it held 3rd gear for a while at about 4k rpm.
aj0294 is offline   Reply With Quote
Old 12-09-2013, 07:05 PM   #6
Angrybird 12
Retired, Cancer Survivor
Angrybird 12's Avatar
Drives: 12 CAMARO, 15 Impala, 07 Colorado
Not only does S mode hold the gear longer it will downshift sooner either in giving it more throttle or when going up hill in cruise control. Going down hills it will hold gear better for engine compression braking.
Cancer's a bitch! Enjoy life while you can! LIVE, LOVE, DRIVE...CAMARO!
The Bird is the word!
Old 12-09-2013, 07:32 PM   #7
aj0294
alright thanks. i knew it would downshift quicker but today was literally the first time it held a gear like that. it kinda freaked me out
Old 12-10-2013, 01:05 AM   #8
Paint It Black
Paint It Black's Avatar
Drives: '11 2SS/RS LS3
I assume this is the same trans behavior seen with the tow/haul mode in the pick ups?
"I see a line of cars and they're all painted black..."
Paint It Black is offline   Reply With Quote
Old 12-10-2013, 05:06 AM   #9
Justin2013ls
Drives: 2014 2SS/RS SIM
I have a 13 ls camaro and I dont think sprot mode comes on mine this true ?
Justin2013ls is offline   Reply With Quote
Old 12-10-2013, 05:11 AM   #10
31B
31B's Avatar
Drives: 2014 Black 1SS A6
Send a message via Yahoo to 31B
LS does not come with a Sport Mode. Only LT and higher.
31B is offline   Reply With Quote
Old 12-10-2013, 08:15 AM   #11
PalmerGA
PalmerGA's Avatar
I don't think so. For one thing, doesn't tow/haul prevent you from driving in OD gear. That's how it works in my Ram. It may well change the shift points though.
Old 12-10-2013, 08:55 AM   #12
Angrybird 12
I think on my 2001 GMC it was that way too, changed shift points and also kept it from going into overdrive..
Old 12-10-2013, 04:33 PM   #13
NJBourne23
Master of Nothings
NJBourne23's Avatar
This is what i was talking about. Thanks for the responses!
Old 12-11-2013, 12:24 AM   #14
Phillyone
Phillyone's Avatar
Drives: 2011 Camaro LS Silver/Black Stripes
My 2011 ls has sport mode.
2011 Camaro LS.Rotofab CAI. Rx Catch Can. SS/RS 20" Wheels wrapped in Pirelli P-Zeros. 17" Msw by Oz wrapped in Blizzaks for the winter. Power Plant Ops.
Purchased August 2013
Phillyone is offline   Reply With Quote
