AAC Style
Old 12-12-2013, 09:13 PM   #43
Burn Notice24
Drives: 2012 Camaro Convertible
Originally Posted by MBS View Post
The Op needs to go to college I am sure Ohio State has a class for how to pump gas , he will be surrounded by athletes .
I appreciate a petty insult as much as the next guy, but why? However, if you want to take a shot at me, I will defend myself. My test scores place me in the top 98% of my class, I attended a summer course at Columbia university this past summer and receive multiple college recruitment letters each month. No one has showed me how to get gas without holding the pump. That doesn't make me an idiot.
Burn Notice24 is offline   Reply With Quote
Old 12-12-2013, 09:34 PM   #44
Cam2011
Cam2011's Avatar
Drives: 2011 Camaro 2SS/RS
I used to have that problem in my old Chevy G-30 van, basically you need to find the sweet spot, and not set the flow full force. Thankfully I haven't had that problem with my camaro (2011), but I stand there just the same to make sure all goes well.
Cam2011 is offline   Reply With Quote
Old 12-12-2013, 09:38 PM   #45
Cam2011
Cam2011's Avatar
OP, I don't know if your local stations have that fume/vapor recapturing system on your nozzles, but that may add to your woes both by not allowing the back pressure to escape (the old HI-C can with only one hole) or by actually springing the nozzle out just enough when you let go to stop the pump.
Old 12-13-2013, 05:25 AM   #46
Stecky
Drives: 0000
(you need to find the sweet spot, and not set the flow full force.)
Thats What SHE said
Stecky is offline   Reply With Quote
Old 12-13-2013, 05:32 AM   #47
Stecky
Drives: 0000
Originally Posted by Nutro View Post
I think the OP means why does the pump keep kicking off because the nozzle depth is wrong.
I Don't know how I missed this one.
Old 12-13-2013, 05:47 AM   #48
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Drives: The one with a roof rack
Bravo. 1 star.
SnoopyAce7 is offline   Reply With Quote
Old 12-13-2013, 05:49 AM   #49
kacmdc
Drives: 2012 2LT RS
Make sure you shake it before you put it away.
2012 2LT RS
Injen CAI
Resonated X pipe's
kacmdc is offline   Reply With Quote
Old 12-13-2013, 06:07 AM   #50
Stecky
Drives: 0000
Thats What SHE said
http://www.youtube.com/watch?feature...&v=SAAi_42uIkQ
Old 12-13-2013, 01:11 PM   #51
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
Originally Posted by Burn Notice24 View Post
I'll start by saying that I am an idiot How do you fill up the tank without having to stand there holding the nozzle?
OP, I feel your pain. Here is some advice:
Pull into the gas station. Pull up to the pump and stop within a reasonable distance so the hose will reach your gas filler door. Put the car in park (if auto) or 1st gear (if manual). Apply parking brake. Turn car off. Take keys out of ignition. Open the car door. Step out of the car and stand up. Close the car door after you've moved your body out of the way of the door. Walk to the gas filler door. Push on it slightly to open it. Then open it completely. Tell the gas attendant the amount of gas you want in dollars. Take the nozzle and insert it into the filler. Pull up on the handle to begin pumping gas. That should do it.
Hopefully we can get a sticky on how to properly fill our gas tanks. And one on windshield washer level indicators.
2017 Camaro ZL-1 A10 - Roto-Fab cai!!
Veronica (2013 Jeep Grand Cherokee Overland 5.7 Hemi) - Tuned!!
Saving the world...1 hp at a time!!
BlaqWhole is offline   Reply With Quote
Old 12-13-2013, 03:17 PM   #52
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Instead of using the gas cap, squeeze the handle all the way and wedge a tennis ball in there. Works great!
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 12-13-2013, 03:28 PM   #53
jd10013
Drives: 2012 camaro
Originally Posted by jshaf View Post
so if you try to put fuel in your own vehicle in one of those states that forbide it do they go nuts on you? call 911 and sh&*? how would this appear on your rap sheet, "felony; fueling own vehicle" LOL, never heard of such a law! I know my mom used to only go to places that filled it up for you, but after a while she gave up and started doing it herself because there wasn't anyone in the area that did it for you any more.
I'm guessing it's a union thing, so if you pumped your own they'd most likely send some muscle to your house to break both your arms so you wouldn't do it again.
jd10013 is offline   Reply With Quote
Old 12-13-2013, 03:30 PM   #54
jd10013
Drives: 2012 camaro
the easiest way is to bring your wife or girlfriend and let her hold it
Old 12-13-2013, 03:36 PM   #55
jd10013
Drives: 2012 camaro
everyone's a genius on the internet.
no, but it doesn't make you too bright either.
that was a joke, try to relax
Old 12-13-2013, 03:40 PM   #56
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
You just need to stick the nozzle all the way in and hope for the best!!
SlowSS is offline   Reply With Quote
