Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 12-13-2013, 07:33 PM   #1
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
Arrow For Sale Front-Rear v8 v6 Camber Adjustment Bolts
Ohio-Speed now carries:
Rear Camber / Toe Adjustment
Double the range of rear camber and toe adjustment on the popular Camaro to increase handling performance and minimize tire wear.
Remove and replace the OE cam bolts with our 87430 kit for +/- 1.0 degree camber change and +/- 2.0 degrees toe change.
No slotting or grinding needed!
2 sets required per car
Rear Adjustment Range:
Camber +/- 1.0 degree
Toe +/- 2.0 degrees
Installation time: .6 hr/side
Required: 1 per wheel
SS v8 EZ CAM XR (16mm - PAIR)
EZ Cams(TM) make non-adjustable two bolt struts adjustable up to +/- 1.75 degree camber change.
Head markings show where the cam is for maximum change and an easy-to-manipulate toothed washer lets you set positive or negative change.
Simply remove the upper OE bolt, loosen the lower bolt, install and adjust the EZ Cam to the desired change and then tighten everything to specification.
This is an easy fix for camber issues and a perfect companion sale for any strut job. Save time, money and effort by making aligning two bolt struts a one man job without grinding.
Keep one of each part number in stock, measure the OE threads, replace the OE bolt with SPC's EZ Cams to make your alignment jobs fast and profitable.
Part No. 81280 - Pair
For replacement of 16mm bolts
This kit may also be used on GM vehicles equipped with aftermarket slotted struts with the addition of our adapter plate, 81286 included with cams.
Front Adjustment range:
Camber -1.75 degree to +1.75 degree
Installation time: .4 hr/side
Required: 1 kit for the front
PM for our LOW Introductory Price!
Ohio-Speed is your #1 Online Store for High Performance Parts and Show Car Accessories!
https://www.ohio-speed.com/default.aspx
TAKE ADVANTAGE OF OUR LAYAWAY PROGRAM!
OHIO SPEED is offline   Reply With Quote
Old 01-01-2014, 08:36 PM   #2
2SS2010
Drives: 2010 2 SS
Are these needed F&R for lowering a V8 1"?
2SS2010 is offline   Reply With Quote
Old 01-06-2014, 03:41 AM   #3
atxcamaross
Drives: '10 Camaro SS CGM
Pm me a price for camber bolts for front and rear please. Thank you
atxcamaross is offline   Reply With Quote
Old 02-23-2014, 10:00 AM   #4
OHIO SPEED
OHIO SPEED's Avatar
FOR SALE: SS or v6 Rear Camber / Toe Adjustment Kit FREE S/H
Sale continues!
Old 10-21-2014, 04:53 PM   #5
OHIO SPEED
OHIO SPEED's Avatar
all pm's sent
camaro, camber, front rear, suspension
