Cold Air Inductions
Old 12-14-2013, 09:27 PM   #1
Addicted2upgrades
Drives: 2012 Rally Yellow 2SS
BMR springs w/ Stock suspension noise ADVICE PLEASE
I have BMR lowering springs 1" drop. I have a BMR sway bar also. The sound coming from the rear is like the sound of having 2 porcelain bowls stacked on each other and when I go over small bumps they raise and rattle for a half second...now I've had an alignment and have been under the car 4 times to re tighten and all that jazz....what I think it is is either the stock shock gave out OR where the shock actually connects to the lower control arm where the bolt goes through is metal on metal....are there any bushings for that or is this normal? I can't find anything related on the forums, though I'm only on 22 ha.
Any feedback is appreciated Thanks guys
pat
Addicted2upgrades is offline   Reply With Quote
Old 12-14-2013, 11:55 PM   #2
Synner
Drives: not stock
Tighten sway bars, check to see if coils are seated.
Shocks going out would not cause those symptoms, its either something loose or the springs.
Old 12-15-2013, 12:17 AM   #3
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Could be the end link nut to the control arm, probably just loose.
Lil' Nasty is offline   Reply With Quote
Old 12-15-2013, 09:13 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I agree with the other two, something is loose.
Old 12-16-2013, 01:58 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
pat
Definitely get up under the car and make sure that everything is good and tight and that nothing is loose. If you still can't get it figured out give us a call here at the shop and we will help you get it all figured out.
