Old 12-16-2013, 10:23 AM   #1
chuckclanton
Drives: 2016 Camaro 1/SS
Lowering springs & rear camber
Will lowering springs put the rear camber range too negative?
chuckclanton is offline   Reply With Quote
Old 12-16-2013, 11:22 AM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Yes, and you will need an alignment afterwards.
Old 12-16-2013, 02:03 PM   #3
camaro1350
camaro1350's Avatar
Drives: 2013 Camaro RS 1LT, 6M
Yes and you will need after market alignments bolts as well. Stock ones will not give you enough positive chamber when you realign your wheels. There are four total in the rear. fronts are fine with stock.
camaro1350 is offline   Reply With Quote
Old 12-16-2013, 02:06 PM   #4
chuckclanton
Coilovers, the same issue?
Old 12-16-2013, 02:22 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
This is a very vague question and I guess the best answer would be that it depends on what you are doing with the car and how low you are wanting to go. What is too much negative rear camber for you? If you are going to be doing some handling style stuff with the car where some negative camber is a good thing than that can easily be achieved with the factory hardware when using lowering springs. If you trying to get close to zero camber in the rear with lowering springs and factory hardware it won't happen, you will either need aftermarket hardware that offer more adjustment or an adjustable lower control arm.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 12-16-2013, 07:38 PM   #6
camaro1350
camaro1350's Avatar
I agree as above and yes coilovers as well. When you lower a car it will force the wheels to negative chamber, so the lower you go the more negative chamber you will have.
Old 12-16-2013, 09:20 PM   #7
Threlkeld's SS
Threlkeld's SS's Avatar
Drives: 2010 camaro ss
I just purchased bmr split drop springs. Will I need new bolts of I go with the performance alignment that you guys recommend?
Threlkeld's SS is offline   Reply With Quote
Old 12-16-2013, 09:28 PM   #8
tanur420
Drives: 2011 Camaro SS
Could you pm me alignment spec bmr?just bought a set of lowering springs
tanur420 is offline   Reply With Quote
Old 12-16-2013, 10:05 PM   #9
Threlkeld's SS
If I not mistaken I think you can get it from their website. It's at the bottom of the installation instructions
