JUICEDMOTORSPORTS
Old 12-16-2013, 09:58 PM   #1
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Solid subframe bushings or toe/trailings?
If you had to choose between a solid subframe bushing (ADM or Pfadt), or upgraded toe rod & trailing arms, which would you pick?
Application:
2010 2SS/RS M6 - daily driver
See signature for mods list (coming soon items expected within next 3 months)
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 12-16-2013, 10:10 PM   #2
ssmike
Missing Big Red
ssmike's Avatar
Drives: '13 Equinox CRT
Start with the solid subframe bushings first! They are the foundation of the entire IRS! Actually, if you can swing it financially, do everything all at once! You'll have to lower the cradle to do the driver's side toe link so might as well do it when you have the cradle down for the bushings! Also, when you do the trailing arms make sure you replace the outer bushings if the don't come with the arms.
Old 12-16-2013, 10:18 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
100% agree with everything Mike said!!!! Good Advice!!!
blazzin1 is offline   Reply With Quote
Old 12-16-2013, 10:22 PM   #4
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
I agree^ Solid Subframe bushings first.
Lil' Nasty is offline   Reply With Quote
Old 12-16-2013, 11:03 PM   #5
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
I just wasn't sure if the step from inserts to solid was as good as the upgrade on the toe rods/trailing arms (with outer bushing).
Old 12-17-2013, 01:41 AM   #6
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Well inserts are better than just then the factory bushings (obviously)
But if you can swing it, full replacement solid bushings are the way to go. Cradle has to come down anyways but thats jmo.
Went with the LSR toe links, trailing arms and they have definitely improved the handling, I also need to get some outer bushings.
Old 12-17-2013, 07:33 AM   #7
ssmike
Missing Big Red
ssmike's Avatar
I had inserts but didn't feel much improvement till I went with the full bushings!
Old 12-17-2013, 07:39 AM   #8
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
You have to drop the cradle a little bit to get the toe rod bolts out anyway. Do it all.
Bo White is online now   Reply With Quote
Old 12-17-2013, 01:45 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
It is best to do them both at once to avoid doing things twice. I also recommend doing the Upper control arm bushings while you are doing the subframe bushings.
Best regards,
Tyler
888-308-6007
Old 08-07-2014, 09:47 PM   #10
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
I did both bushings with my BMR trailing arms.
You WILL notice that poly outer bushing the first time you drive it. It gives "feedback" on road condition and things out back don't move around as much.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 08-07-2014, 10:12 PM   #11
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Exactly.
