sjm autoprod
Old 12-17-2013, 12:13 PM   #1
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
2 New 1LE Suspension Kit Part Numbers
I don't know if anybody's posted this up or not, but I got my 2014 Chevrolet Performance Parts Catalog yesterday and there's 2 new part numbers in it for 1LE suspension kits. I don't know why, but I don't think that the 1LE rear cradle bushings ever became available in 2013 and that kept the 2013 1LE suspension kit from becoming available. I know that Parts Taxi was selling all the parts, except the rear cradle bushings, in a kit. It looks like for 2014 GM has left the rear cradle bushings out and gave it 2 new part numbers, one for V8 apps and one for V6 apps. It looks like the only difference between the two is that the V6 kit includes the front springs. I checked the part numbers on GMPartsDirect and both numbers are pricing at $1144.50, which makes me wonder why anyone would buy the V8 kit. The notes say that the V6 guys will also have to upgrade to the V8 brakes(Part#'s 23120542 and 23120543) to use the kit. It looks like they have changed the part numbers for the front struts also. I don't know if that means that they have improved them, but maybe...
The new numbers are:
2014 1LE Track Pack(V8)…………………….……….....23123397
The kit includes:
Front Stab Bar Asm (bar, links, bushing, clamp, nut)....22812942(1)
Rear Stab Bar Asm (bar, bushing, clamp, bolt)……......22786260(1)
Rear Stab Bar Link……………………………………......22761221(2)
Front Strut Asm, LH (strut, spring, mount)……………...22812984(1)
Front Strut Asm, RH (strut, spring, mount)……………..22812985(1)
Rear Shock…………………………………………….......23115372(2)
Rear Shock Mount, LH…………………………………....22922445(1)
Rear Shock Mount, RH…………………………………...22922446(1)
Rear Toe Link……………………………………………....22845487(2)
Nut-FRT STAB HYD SHF Link.......................................1151607 8(2)
Emblem-F/End UPR Tie Bar..........................................22942 442(1)
Nut-FRT SUSP Strut MT................................................ 11569638(2)
Nut-RR S/ABS (UPR)............................................. ........11516078(2)
Installation Instructions………………………………….. ..23123399(1)
2014 1LE Track Pack(V6 )…………………….………......23123398
The kit includes:
Front Stab Bar Asm (bar, links, bushing, clamp, nut)......22812942(1)
Rear Stab Bar Asm (bar, bushing, clamp, bolt)……........22786260(1)
Rear Stab Bar Link……………………………………….....22761221(1)
Front Springs........................................... .........................92245257(2)
Front Strut Asm, LH (strut, spring, mount)…………….....22812984(1)
Front Strut Asm, RH (strut, spring, mount)…………….....22812985(1)
Rear Shock………………………………………………......23115372(2)
Rear Shock Mount, LH…………………………………......22922445(1)
Rear Shock Mount, RH…………………………………......22922446(1)
Rear Toe Link……………………………………………......22845487(2)
Nut-FRT STAB HYD SHF Link.........................................11516 078(2)
Emblem-F/End UPR Tie Bar............................................229 42442(1)
Nut-FRT SUSP Strut MT................................................ ..11569638(2)
Nut-RR S/ABS (UPR)............................................. ..........11516078(2)
Installation Instructions(V6)..…………………………….....23123400(1)
Installation Instructions(V8)..…………………………….....23123399(1)
For comparison, here's last year's numbers:
2013 1LE Track Pack……………………….………............231023311
The kit includes:
Front Stab Bar Asm (bar, links, bushing, clamp, nut).........22812942(1)
Rear Stab Bar Asm (bar, bushing, clamp, bolt)……...........22786260(1)
Rear Stab Bar Link………………………………………........22761221(2)
Front Strut Asm, LH (strut, spring, mount)……………........22812982 (1)
Front Strut Asm, RH (strut, spring, mount)……………........22812983 (1)
Rear Shock……………………………………………….........22981391 (2)
Rear Shock Mount, LH………………………………….........22922445 (1)
Rear Shock Mount, RH………………………………….........22922446 (1)
Rear Toe Link…………………………………………….........22845487 (4)
Rear Cradle Bushing, Front…………………………….........20941932 (2)
Rear Cradle Bushing, Rear……………………………..........20941933 (2)
]Installation Instructions…………………………………........23102312 (1)
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
Old 12-17-2013, 12:40 PM   #2
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Interesting. Not that it's a big deal or anything, but they're tossing in a Chevrolet Performance emblem for under the hood. p/n 22942442 Lists for $31.60
But doesn't the SS already have this emblem or did they drop that? I know 1LE and ZL1 already do, and I'm guessing the V6 doesn't?
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 12-17-2013, 01:18 PM   #3
Rocky1974
Rocky1974's Avatar
Yeah, there's quite a story behind those emblems. GM installed the "GM Performance Division"version on the early 2010 SS's, but dropped them on the late 2010's, 2011's, and 2012 SS's. They reappeared on 2012 ZL1's and 2013 SS's. But, sometime during the 2013 model year they switched to the bowtie version you have pictured. I guess they are including them in the kits for the V6 guys and the late '10-'12 guys who didn't get them.
Old 03-09-2015, 09:30 AM   #4
Marlon1LS
Marlon1LS's Avatar
Drives: 2012 Camaro 1LS w/L99/TR6060
Would these new part numbers work for 2012 v6?
Marlon1LS is offline   Reply With Quote
Old 03-09-2015, 11:10 AM   #5
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
Yes, the 1Le Kit was made available especially for pre-2013 Cars!
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 05-29-2015, 03:59 PM   #6
Marlon1LS
Marlon1LS's Avatar
I've been taking to a near by dealer and they don't seem to be savey or enthused enough to know which part number to use for my 2012 v6. Any inputs or suggestions?
Old 05-29-2015, 04:26 PM   #7
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Here Bros'
Go to the dealer and ask for this part number: P/N 23123398 (V6)
http://www.chevrolet.com/performance...s/1le-zl1.html
Old 05-29-2015, 05:44 PM   #8
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Before you buy a 1LE kit, check out the Z/28 Light Kit.
http://www.camaro5.com/forums/showth...t=z%2F28+light
"So I just took her to the local xxxxxx that has a nice little paved oval (parking lot) out front and did some hairpin turns. O.....M.....G Holy Shit does it turn. Better now on cold tires than before on hot tires!!!!!" according to Bill. We'll hear more from Bill after his day at Watkins Glen.
Bill Hurd likes to run his 1LE at Watkins Glen International. For road course use his most valuable modification to date has been his StopTech brake upgrade. The next step is to improve his grip. We are approaching that in several ways.
First we are upgrading to Z/28 springs. The rates are much higher. They are very similar to the set we had been using for years on coilovers. Nick Grossman has retail kit #1. He and his wife Melanie drove their Z/28 light Camaro from Virginia to Indiana and loved the changes.
The dampers are not a perfect match to the coil, but they work quite well. Too bad the rear Z/28 coil is 3/4 of an inch too short to fit on a 1LE rear strut. That would stop most companies or shops, but not JPSS. At JPSS we don't let little things like that get in the way of a great upgrade. We use a little 'Black Magic' and make it work.
Up front we'll be installing Black Magic Caster Lock for a gain of 1 degree. We'll also install Billet Bushings in the radius rod to reduce dynamic caster changes. Up top we'll instal Knock Out Camber plates. We should really call them SAI plates. Adding Steering Axis Inclination improves straight line stability and the return to center after a turn. You cannot imagine how sweet it is to drive with increased caster and SAI.
We'll be swapping out the 1LE front 27mm sway bar and installing the almost 24mm SS front bar. We'll add our OE Quiet HD High Efficiency Endlinks to the new SS bar. This will allow the 1LE to rotate more. It isn't snap oversteer. We like to call it aggressive rotation. As they say in the movies, loose is fast.
On the alignment rack we'll be aggressive road course.
Front Camber -2.50
Front Toe OUT 0.50
Rear Camber -1.25
Rear Toe IN 0.12
Z/28 Light Parts List
GM 1LE Struts
GM Z/28 Coils
GM Front or Rear Sway Bar Depending on Model and Year
JPSS Billet Radius Arm Bushings
JPSS Caster Locks
JPSS ships the kit fully assembled using your old mounts and hardware. We turn around the kits in 72 hours or less. We can also build a kit from scratch, but the new mounts, insulators, etc... are expensive.
Buy Now!
Old 07-10-2016, 11:14 PM   #9
Mattswla
Drives: 2014 SS L99
Hey guys, am I reading correctly that the v6 1le track pack kit is the same as the v8 kit except that the v6 kit includes different springs? I have a friend that bought and hasn't used a 1le suspension kit for his v6 and is gonna sell it for cheap. I'd like to buy it if it will work on my ss. Thanks for the help!
Mattswla is offline   Reply With Quote
Old 07-11-2016, 08:30 AM   #10
derek1387
Drives: 2015 1LS Red V6
Itll work. If you have the SS, just swap the springs over.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 07-11-2016, 11:23 AM   #11
Mattswla
Drives: 2014 SS L99
Do y'all think 600 bucks is a bargain for this kit?
Old 07-11-2016, 01:16 PM   #12
derek1387
For a take off 1LE Kit? As long as it's not all beat to hell, sure.
I paid $400 plus shipping.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 07-13-2016, 07:21 PM   #13
Mattswla
Drives: 2014 SS L99
It's actually a new in plastic kit that was never installed. He ended up selling his car before installing it. I'm going to see if I can work the price down a bit.
