Caryle Racing
Old 08-29-2009, 09:41 PM   #15
JoyWReynolds
Drives: 2010 Black 2SS
white exhaust smoke
I just bought my 2010 2SS today, and had LOTS of white smoke from the exhaust earlier! Anyone else found any reasons for this???
JoyWReynolds is offline   Reply With Quote
Old 09-07-2009, 11:59 AM   #16
F8WillW8
F8WillW8's Avatar
Drives: 2010 CGM 2SS/RS
Just under 1000 miles on my 2ss (A6) with no issues... until last night! Went to a movie, so the car had been sitting for about 2 hrs. Let it warm-up for a couple of minutes and then drove off (gently, no heroic movie theater antics!). The theater is in a neighborhood, so it took several minutes of slow driving to get the main road. At the light, there was a car in front and a car behind... normal acceleration. We were taking a left so I let off the throttle as we took the corner (again, car in front and behind!). As soon as we got around the corner and I gave a bit of gas (bit... car still in front, wasn't in the mood for a Honda hood emblem), an enormous cloud of thick white smoke came belching forth from the exhaust. This was 10pm, just street lamps and headlights to judge the smoke color through the auto-dimming rear view mirror, but it still appeared to be pure white, not blue-white or black'ish. I had a fairly good look at it because it was sooo thick I could just barley see the highlights of the car behind me peeping through my "James Bond-style" smoke screen. If this amount of smoke had come from the tires I might have felt differently!
As we drove down the road, my mind replaying the day searching for a memory that could help explain this rather disturbing event... it happened again!! At the next traffic light! Similar event, deceleration then a bit of gas. Pulled over to administer a "sniff" check to the tail pipes, no real pronounced aroma certainly not a burning oil smell. So, home I went gentle all the way. Once in the garage, I gave the pipes another smell test and wiped my finger around the inside edge of the tail pipe. No real pronounced smell, it was several miles to get home. There was a bit of black residue in the tail pipes, maybe just from a rich fuel program?
This morning I checked the oil (dip-stick and fill cap) for signs of the "milky" evidence of coolant in the oil. No sign of coolant in the oil, however I did notice a few small metal shavings on the dip-stick, 950 miles... time for that first oil change!
One thing that did happen yesterday was a shifting glitch. I was leaving the neighborhood in Sport Mode (A6). As I pulled on to the main road I gave her some throttle, the car quickly went past what I expected for a shift point. I let off the throttle somewhere between 4500 and 5000 RPM, let it slow itself down, came to a stop, started over again. Everything settled down and it shifted as expected for the rest of the day. I just assumed that the car was under the impression that I was next to a Mustang and wanted it hold on to those shift points.
Based on the what happened later that evening, I'm wondering if this car has a vacuum modulator on the transmission that is having issues. This could perhaps explain the shifting glitch and if the modulator pulled to high of a vacuum perhaps it sucked some transmission fluid through the vacuum line into the intake manifold and from there into the combustion chambers.
The car is stock except for GM Performance mufflers.
Needless to say, the car is going back to the dealer for a check-up! They better have a realistic explanation and not a dealer SWAG.
Anyone have any thoughts or suggestions?
F8WillW8 is offline   Reply With Quote
Old 09-08-2009, 12:16 AM   #17
Rcamaro
drive hard
Rcamaro's Avatar
Drives: 2nd Gen Camaro
Originally Posted by tooltimetim View Post
my 2010 2SS had 6 miles when i picked up frm dealer - @ 25 miles white smoke started coming out of tail pipes. stopped car no indication of problem. smells like burnt rubber..drove 10 more miles tday - seems to be OK - anyone else see this?
Its normal, nothing to worry about. Like others have said, also the paints and metals on the engine heating up for the first time or even third time are still burning and fuming off. I even noticed this when i went to test drive some new hondas, yotas and nissans shopping for a future vehicle ( until i found the camaro of course) and they all had the same white smoke when test driven. This is all just coming from what ive always experienced with freshly built vehicles. I wouldn't worry it all should be normal enjoy your ride
Last edited by Rcamaro; 09-08-2009 at 04:20 AM. Reason: was responding to original post
Rcamaro is offline   Reply With Quote
Old 09-08-2009, 01:12 AM   #18
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
Water in intake - car washed? Puddles? Remove air filter and check for moisture in filter box.
Head gasket leak - chemical test can reveal leaks where there is no oil contamination.
Among other possible causes.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP Graduate, A.S. Automotive Technology, Telecommunications Specialist, CISCO Certified Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 09-22-2009, 02:40 AM   #19
shockandawe
shockandawe's Avatar
Drives: 2014 Z51 Corvette
I've got the 6 speed auto with 1600 miles. I tried to do a burnout with my foot on the brake,as I gave it the gas,it was belching gobs of white smoke. i took it to the car wash and tried it again,this time with no foot on brake and I still got white smoke,but not as bad.
shockandawe is offline   Reply With Quote
Old 09-22-2009, 03:59 PM   #20
dwhite
Drives: Inferno orange ss v-8
Before the lifters were replaced did your car idle rough at a light. And if so does it still do it.
dwhite is offline   Reply With Quote
Old 09-22-2009, 06:06 PM   #21
DEW
Drives: Hoopdee
Check each sparkplug for oil contamination in the combustion chamber. If one looks different than all the others, you have narrowed your problem down to that cylinder.
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 09-22-2009, 06:15 PM   #22
F8WillW8
F8WillW8's Avatar
Dealer replaced all 16 lifters. Oil in the intake. Apparently an "over aggressive" lifter will build-up pressure that gets vented through the valve cover (similar to the old PCV valve). Oil gets vented into the intake and then into the combustion chambers.
Old 09-23-2009, 02:36 AM   #23
shockandawe
Did 4 burnouts today and could not duplicate white smoke. Put car in garage and revved to 4 grand and held it there,no smoke. Does anyone know if this is a re-occurring problem or just occasional?
Old 09-27-2009, 12:13 AM   #24
Guns
Drives: 2010 Black SS/RS
There is another thread on this subject that includes a generic service bulletin on the issue. I had excessive bluish white smoke, rough idle, and severe hesitation. Dealer is replacing the lifters.
Guns is offline   Reply With Quote
Old 09-27-2009, 12:35 AM   #25
Silverghost
Silverghost's Avatar
Drives: Z28
Link to thread with bulletin
http://www.camaro5.com/forums/showth...xcessive+smoke
Speed Kills - Drive a Ford and live forever!
www.rivercityperformance.com
Silverghost is offline   Reply With Quote
Old 09-29-2009, 11:16 AM   #26
Triton2110
LUV'N THE CAMARO
Triton2110's Avatar
Drives: 2110 2SS RS
Dealer replaced all 16 lifters. Oil in the intake. Apparently an "over aggressive" lifter will build-up pressure that gets vented through the valve cover (similar to the old PCV valve). Oil gets vented into the intake and then into the combustion chambers. Camaro at 650 miles.
I am concerned about long term effects.
Triton2110 is offline   Reply With Quote
Old 11-15-2009, 07:27 PM   #27
SuperTrooper
Drives: 2010 SS/RS Camaro
My car did this friday afternoon and I guess I will be taking it to the shop monday to see what they want to do about it.
SuperTrooper is offline   Reply With Quote
Old 12-07-2009, 10:50 PM   #28
BearDownSS
Drives: 2010 Camaro 2SS/RS orange
white smoke
Hey guys this is my first post. I just got my Camaro on Saturday, and I've had the same issue with my car. The smoke hasn't been as bad as the first time it happened, but it still makes an appearance every once in a while. I took it to the dealer and they told me that they couldn't find anything mechanically wrong with the car. They told me that they just think that the engine is just breaking in. Has this been the case with any of you guys? Did this issue just go away?
BearDownSS is offline   Reply With Quote
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
RATING HEADERS??? SAUCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 12-02-2011 09:21 PM
EXHAUST Milk 1027 Wiki 2 03-07-2010 10:20 PM
Heard exhaust of L99 tonight - OMG!!! Hylton 5th Gen Camaro SS LS LT General Discussions 60 03-06-2010 06:03 PM
(UPDATED) Stainless Works exhaust and header systems!! (Tag's SS w/ HP #'s) Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 162 07-09-2009 07:39 AM
