Caryle Racing
Old 12-17-2013, 04:12 PM   #1
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
1le suspension swap
hey all, I am swapping from my fe3 suspension set up to the 1le sways/control arms/end links. i just had a question or two concerning the lower control arm and the rear shock. how hard is it to put back onto the control arm? i guess my concern is how difficult will the whole process be to install all the parts?
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 12-17-2013, 04:47 PM   #2
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
For me it wasn't that hard it just took so time. Changing the rear toe links was the most difficult part of the process. But i did the full kit. If your not changing the shocks then its easy. Just remove the control arm and mount the new one. you will probably have to compress the shock a little as it'll move outward after you take the control arm off. It should all line right back up otherwise. Then the sway bar will take a bit of maneuvering to get in but isn't too difficult.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
