BORLA
Old 12-17-2013, 11:49 PM   #1
Mint
Mint's Avatar
Drives: 2013 Camaro SS
Eliminating the raspy sounds
Hey guys,
I've been searching around the forums for a while now but couldn't seem to find what I've been looking for. I have a 2013 Camaro 1SS (L99) and I recently added a Flowmaster American thunder series axle back exhaust with Borla LT offroad headers (no cats). Now I get this annoying raspy sound past 2500 RPM
I know the rasp sound is because there is a mid pipe instead of cat converters but I wanted to tone it down.
I was looking at a MagnaFlow x-pipe (11386) instead of the stock L99 resonator. Would this calm down the Rasp? If not, what other options would there be? I don't believe that there are high-flow cats that can connect to these headers but if so please tell me.
Main Question: Will http://www.summitracing.com/parts/mpe-11386/overview/ in replace of stock L99 exhaust resonators help quiet down rasp?
Thanks to anyone who helps me
Mint is offline   Reply With Quote
Old 12-18-2013, 12:12 AM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Are you sure its not a rattle?
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 12-18-2013, 12:16 AM   #3
Mint
Mint's Avatar
No rattle. Its hard to explain fully. Its not the deep exhaust sound. Its more rasply/ higher pitched. Kinda sounds metally like a tin can at some points.
Old 12-18-2013, 12:31 AM   #4
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
If its definitely rasp then a standard xpipe won't really help, might even make it worse. Magnaflow offers a resonated xpipe that helps reduce rasp, not sure if thats the one you listed. Look in to it
Old 12-18-2013, 12:37 AM   #5
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
Yea the borla LT are very raspy....
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 12-18-2013, 07:38 AM   #6
jman17
jman17's Avatar
Drives: 2011 SS-2/1969 SS
You may actullay be hearing the drive train. Headers will make the actual engine noises more pronounced.
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: 470 rwhp/437tq; Cam: Pat G designed/EPS Ground (228/234 .629”/.629” 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8” Long Tube Headers, Dynomax Bullet Cat-Back System, Cold Air Induction CAI system, RX Performance Catch-Can, Skip Shift Eliminator
jman17 is offline   Reply With Quote
Old 12-18-2013, 09:14 AM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Resonated X pipe will help a little but the only way to really silence it is to slap on some high flow cats.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-18-2013, 09:40 AM   #8
Mint
Mint's Avatar
Thanks. So the MagnaFlow resonated x-pipe will be quieter/less raspy than the stock resonator on the L99? That's what i'm hoping for.
Old 12-18-2013, 12:31 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Correct, It will definitely help a lot, but just about anything anything short of adding cats will not completely eliminate the rasp.
Let us know if you have any questions.
Best regards,
Tyler
888-308-6007
Old 12-18-2013, 12:48 PM   #10
Mint
Mint's Avatar
Best regards,
Tyler
888-308-6007
Thanks,
If a resonator isn't enough... What hi-flow cats, if any will be able to fit on my setup?
Borla XR-1 LT headers (17249) With the factory exhaust
Headers had a 2.5in collector w/ midpipe
Old 12-18-2013, 10:23 PM   #11
axis
Search Ninja
axis's Avatar
Thanks,
If you're still running the factory L99 resonator, I highly doubt the magnaflow version is going to make much if any difference, in sound. As far as HFC's, you'll need to get with Borla to see what they recommend. From looking that them, it appears as though you'll need to do a little fab work to get them to work. I'd bet some slip-ons would fit with a little bit of cutting. If the collector is 2.5in, you'll need 2.5in to 2.5in slip on HFCs.
Halltech CF 102 fed
Old 12-18-2013, 11:44 PM   #12
Camarodriver2
Camarodriver2's Avatar
Drives: Bumblebee 1 of 1
With your setup, if you remove the stock center resonator, you'll go from raspy sound to full-on DRONE. You may want to change out the mufflers for Magnaflow for a deeper sound. The stock exhaust was actually designed properly and we're trying to make them sound like modified race cars. Fun, but an expensive learning process.
Camarodriver2 is offline   Reply With Quote
Old 12-19-2013, 12:04 AM   #13
axis
Search Ninja
axis's Avatar
The factory mufflers do a very good job at eliminating drone. It's when you move to aftermarket mufflers, the drone appears.
Halltech CF 102 fed
Old 12-19-2013, 12:55 AM   #14
Mint
Mint's Avatar
Thanks for the replies. Drone doesn't affect me much due to my lack of highway driving. What is getting me annoyed is the raspy tin can sound from the exhaust. It's not as bad as others say theirs is but it's there. I'm going to try swapping the stock resonator for the magnaflow one. See if it works.
camaro, exhaust, headers, rasp
