Emblempros
Old 12-19-2013, 11:30 AM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Anly one running 1LE track pack with Stock SS tire sizes?
I have a track pack coming since I do all the IT work for my dealership. I do not have the funds at the moment to move to a square setup but will down the road. I am not tracking the car just want it to handle better on the street and keep the warranty.
Thanks ahead of time for posting.
Scott@Bjorn3D is offline   Reply With Quote
Old 12-19-2013, 01:42 PM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
You'll be just fine. You will still see a noticeable handling improvement. The only time you will notice the understeer from the staggered setup is when you are at the edge of traction and the front will push. If you are not tracking the car, you should not really run into this issue on the street.
Best regards,
Tyler
888-308-6007
Old 12-19-2013, 06:48 PM   #3
chuckclanton
Drives: 2016 Camaro 1/SS
The front 245's are the real weak link. My stock 2014 SS was a totally different car with 255/45/20 on 9in wheels up front and 275/40 /20 on 10in wheels in the rear. The PZero 245's have less than an 8in tread width, the 255's a full 9 in. and a bit taller than the rears. The 1LE front bar is going to really make your car push with the 245's
chuckclanton is offline   Reply With Quote
Old 12-19-2013, 08:05 PM   #4
Scott@Bjorn3D
So what would be the widest tire I can put on the stocks front that will match up with the 275 rears and not throw off the ABS with its size?
Old 12-19-2013, 08:14 PM   #5
toehead93
Drives: 2014 2SS/1LE
You could go with ZL1 swaybars which are setup to balance out the staggered tire setup.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 12-19-2013, 08:20 PM   #6
Scott@Bjorn3D
So could I run 255/45/20 on the stock front rim? Would it cause and issue with the ABS? I can get the BFG Comp-2's which I was thinking of getting in that size.
Old 12-19-2013, 09:12 PM   #7
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
We are full 1LE swapped and have autocrossed with both stock 245's and 275's up front noticeable difference between the 2 sizes
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 12-20-2013, 09:19 AM   #8
chuckclanton
Front 8in wheel is too small for 255's. Keep your stock front sway bar on until you can get bigger front wheels and tires.
Old 12-24-2013, 01:22 PM   #9
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
I ran the 1LE sway bars with the stock 245/275 staggered set up. It worked pretty well but I had 1.2-1.4 negative front camber which kept the car very neutral at the track and autocross. I now have the 1LE bars with 275's on stock nine inch wheels all the way around and 1.0 negative front camber; it has frustrating understeer and excessive outer tire wear at the track and autocross.
The 1LE bars with 1.4 negative front camber/1.0 rear camber and 245/275 tires is a good set up based upon my experience.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Cuda7050 is offline   Reply With Quote
Old 12-24-2013, 07:25 PM   #10
chuckclanton
You defied the laws of suspension dynamics! something else going on. 245's neutral and 275' push? could have been pushing the car a lot harder
with the 275's. earlier turn-ins? braking late? etc. I've run both tracks with my Viper years ago and the entry into the main straight on both tracks is really tricky.
Old 12-24-2013, 07:36 PM   #11
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Yup, I have the 1LE track pack with the stock 20's and it only pushes when driven at its limits. For me its just fine for whats a daily driver but I will change the wheel and tire package at some point.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 12-24-2013, 07:51 PM   #12
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Im running the standard SS staggered Pirelli set up.I've done 2 track days on this set up.Defiantly different handling.
cornerspeed92 is offline   Reply With Quote
