BeckyD @ James Martin Chevy
Old 12-23-2013, 07:57 PM   #1
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Subframe bushings diff noise
Just installed some polyurethane differential bushings and wanted to know if anyone else has them installed and if after the install you are able to hear the driveshaft engaging at low speeds when letting off the accelerator and re applying it. I know there is some slack in the drivetrain in this area just never heard it before with stock bushings. Before anyone asks I ensured all the bolts were very tight to spec of course
c_LoW29 is offline   Reply With Quote
Old 12-23-2013, 08:10 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
I assume you're talking about the diff bushings and not the subframe ones? Assuming that's right, the diff bushings are known for transmitting a bit of noise after replacing those.
Old 12-23-2013, 08:26 PM   #3
c_LoW29
Yes the diff bushings. It only happens at low speeds like parking lot areas when there is slack in the driveshaft and I take it out by pressing the accelerator it has a tap noise that follows
Old 12-23-2013, 08:38 PM   #4
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Generally from what I've seen on the forums, a lot of guys only upgrade the cradle bushings, and leave the diff bushings alone for the reason you made this thread. I just got my poly bushings, but I didn't order the diff bushings, just the cradle ones. You get added NVH when you replace the diff bushings.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 12-23-2013, 08:43 PM   #5
c_LoW29
Ok so then it is normal just wanted to get some feedback from people that have actually used them and has the same issue
Old 12-23-2013, 09:08 PM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Yes, it is completely normal. If you put stiffer bushings on the diff you are going to hear gear/drivetrain noise.
Old 12-23-2013, 09:22 PM   #7
tanur420
Drives: 2011 Camaro SS
How noticeable is the diference?
tanur420 is offline   Reply With Quote
Old 12-23-2013, 09:33 PM   #8
Apex Motorsports
It depends on the bushings you go with and even then can vary from car to car depending on how the gears are set up.
Old 12-23-2013, 09:36 PM   #9
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Any chance an aggressive exhaust note might cover the added noise?
AG1LE is offline   Reply With Quote
Old 12-26-2013, 11:07 AM   #10
spd2612
Drives: Black SS2/RS LS3
Drive Line Noise
No the exhaust will not cover it up I have done the diff bushings and Phadt sub frame mounts and my car sounds like a four link car I don't really like the drive line noise but I guess sacrifices just have to be made for performance
Just a note I have 3 inch exhaust with a large cam and you would not want a exhaust any louder than mine and I still here all the drive line noise ( some wining from gears, clunk from drive line slack and some clutch pak noise
SOO if you dont want the noise leave the stock diff mounts
spd2612 is offline   Reply With Quote
Old 12-26-2013, 01:29 PM   #11
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
The radio at regular volume covers the noise quite well. Definitely worth it though. You should look up videos of how much the rear end moves with stock bushings.
SUX2BU is offline   Reply With Quote
Old 03-01-2016, 07:10 PM   #12
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
Any body have a incabin video of the noise . ???I have some whiteline diffrentral bushing I never installed Becase I wasn't sure how loud it would be .
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 03-02-2016, 06:16 AM   #13
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
I do, Pm me your email and I will send you a you tube link. Its very noticeable.
BFASTNOTLAST is offline   Reply With Quote
Old 03-02-2016, 11:18 AM   #14
BMR Sales
BMR Sales's Avatar
Drives: Race Car
This is normal. You have to understand that there is movement & vibration in the Diff and this is absorbed by the Soft Rubber Bushings. When you upgrade the Bushings to a harder material (High Durameter Poly or Solid Delrin), the Noise & Vibration are not able to be absorbed by these materials and when therefore be transmitted through the car.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
