JUICEDMOTORSPORTS
Old 12-26-2013, 10:58 AM   #15
Rob21sf
Rob21sf's Avatar
Drives: Black 2011 Camaro LLT
Originally Posted by BottleFEED View Post
How much of a drop in the stage 2 give you and are you running a 20X11 ?
I believe the rear is 1.25" per Pfadt. I'm running a 20X10.5 rear wheel.
Rob21sf is offline   Reply With Quote
Old 12-26-2013, 06:57 PM   #16
BottleFEED
BottleFEED's Avatar
Drives: 2010 2SS/RS M6
Thanks guys I am gonna talk to the Dougfr when I order the rims an tires. He told me there has been people running a 20x10 an 20x11 with out issues. I might go a little smaller in the fronts like 20x9 not sure if a 10 inch would turn well..
BottleFEED is offline   Reply With Quote
Old 12-27-2013, 06:33 AM   #17
blackSSRS
Drives: 2010 RS
Im also scratching my head about this, wanting bmr 1.4 springs with 22x9 front and 22x10 or 10.5 rear and not sure if itll work. What is your offsets? Im wanting like a 265\30 front and 305\25 rear tire but need help before getting
blackSSRS is offline   Reply With Quote
Old 12-27-2013, 01:31 PM   #18
BottleFEED
BottleFEED's Avatar
UF4LIFE is running a 1.5 drop on 22's with 315's in the back so you should be good. I talked to Dougfr about fitting 315's and the only issue I have to worry about is to tie the brake line back a little...
Old 12-28-2013, 01:05 AM   #19
DESERTDOG
DESERTDOG's Avatar
Drives: 2012 ZL1 M6 Summit White
I have the Pfadt ZL1 Camaro, running their complete front and rear suspension parts, lowered, have the stock ZL1 black wheels, just put on 295-30x20 front, 315-30x20 rear, no rubbing, no clearance issues at all.
DESERTDOG is offline   Reply With Quote
Old 12-28-2013, 01:38 AM   #20
BottleFEED
BottleFEED's Avatar
How low of a drop ? Have pics?
Old 12-28-2013, 08:12 AM   #21
xtreme2s
Drives: Livernois Motorsports 2010 2SS/RS
The correct offset is the big requirement. I'm running the 315 Nitto's mounted on CCW 505a rims 20x11.5 in back, and 20x10 in front (CCW website has all measurements for reference and upon my ordering they were great to work with. Easy!)
Also have had 2 different suspension set up's with this rim/tire combo. My very first mod just after purchase of Camaro was springs/sways and rims/tires. Ordered Detroit Speed & Engineering spring set up. Then after a year plus, stepped up into new version, complete Phadt Stage 4 coil over suspension when they launched it at CF4.
No issues with either suspension package with the 315's in back
I only had to tie back the parking brake line, as it rubbed with my deep rims (lowered or not this is required) I have noticed upon removing rear tires, that I have rubbed the inside of fender liner, however since doing some auto crossing is reason.
xtreme2s is offline   Reply With Quote
Old 12-29-2013, 12:00 AM   #22
DESERTDOG
DESERTDOG's Avatar
Drop must be 1.25" front maybe 1.5" in rear...sits pretty level.
Old 12-29-2013, 09:46 AM   #23
randy's2012
randy's2012's Avatar
Drives: 2SS/RS, supercharged LS3
I have a question about lowering my 2012 SS. I just got done lowering the car 1" all the way around. Although I bought and installed just a 1" drop spring the car sits so low to the ground right now. I have a low profile small floor jack and when I lowered the car I couldn't get the jack out. Only way to get frame off of jack was to jack the car back up and place 2X6's under the front tires. This just gave me enough room to work the jack out from under the front of my car. My question is did I get the right springs and only lowered my car an inch. Has any one else seen this issue when just dropping the car 1"? Should there be a certain ground clearance from the front frame to the ground and if so what should that be? I could use all of your knowledge in finding out that I got the correct springs.
randy's2012 is offline   Reply With Quote
Old 12-29-2013, 08:49 PM   #24
xtreme2s
Yup most of us with lowered Camaro's and for those with ground kits! I'm both lowered and with GFX so I must drive car up on my Race Ramps first, then use my low-pro jack. (the RR versions I have are for my car trailer door)
Old 12-29-2013, 09:12 PM   #25
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Mine fits after I pick up on the car about a half inch. Its no big deal.
Old 12-29-2013, 09:27 PM   #26
rozay
rozay's Avatar
Drives: camaro 2LS LFX A6
Im guessing it depends on your offset for example im going with the fr zl1 rep 20x10 +23 all around with 275 40 20 and i think from the offset im hoping ill be good or maybe i should get 275 35 20? "Scratching head"
Niche 20x10.5, BMR 1.25 springs, GFX splitter,1LE Diffuser w/ 3.5 quad tips
rozay is offline   Reply With Quote
Old 12-30-2013, 12:20 AM   #27
BottleFEED
BottleFEED's Avatar
I'd talk to Doug or one of the people from factory reproductions and they can tell you what works an what doesn't. If I can fit a 20x11 wrapped in a 315 on a 2 inch drop 2010 ss then you should be safe as well.
Old 12-30-2013, 11:03 PM   #28
DESERTDOG
DESERTDOG's Avatar
Its the downside to lowering...giving up suspension travel, and bringing the bottom of the car closer to the ground. Lowering you Camaro 1" shouldn't have made it that bad...maybe it is lower than the aftermarket springs said they would do. Go to the dealer and measure a new one, front and rear, then measure yours at the same place, top dead center of each side wheel well. See what that difference is.
