sjm autoprod
Old 12-25-2013, 02:11 PM   #1
PDP_SS
Drives: 2013 SS
How low can you go
I'm wanting to lower my car but the lowest I have found is 1.5 from BMR is there lower or is that the safest
PDP_SS is offline   Reply With Quote
Old 12-25-2013, 02:18 PM   #2
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Is it a dedicated track car or do you drive it to work every day?
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake | Pfadt Suspension | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 686rwhp/590rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 12-25-2013, 02:20 PM   #3
PDP_SS
Drives: 2013 SS
It's my daily
Old 12-25-2013, 02:22 PM   #4
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
You can get lower with coilovers, http://www.andysautosport.com/chevro...c01019019.html
Or you can drop it to the ground on bags
RolltideSS is offline   Reply With Quote
Old 12-25-2013, 02:22 PM   #5
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
What is your budget?
Old 12-25-2013, 03:42 PM   #6
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
If you go to low it can mess with your suspension.
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
angie7 is offline   Reply With Quote
Old 12-25-2013, 03:51 PM   #7
erik13
erik13's Avatar
Drives: 2010 1LT RS
why???
erik13 is offline   Reply With Quote
Old 12-25-2013, 03:57 PM   #8
Way Too Fast Motorsports
Way Too Fast Motorsports's Avatar
Drives: 349 Stroker E85 Powered Miata
coilovers if you wanna go lower than springs and still be able to handle. Make sure you increase spring rates as you go lower so you don't bottom out.
Way Too Fast Motorsports is offline   Reply With Quote
Old 12-25-2013, 04:37 PM   #9
BottleFEED
BottleFEED's Avatar
Drives: 2010 2SS/RS M6
There is 2 inch drop springs which are what I am running.. The ride is the same as a 1.5 drop I just wanted it a little lower. If you are looking to go cheaper just replace your springs if you have a few thousand go with coils overs. Remember thou if you want to stick different rims an tire combos on go with 1.5 drop springs. It's cheap an easy to do..
BottleFEED is offline   Reply With Quote
Old 12-25-2013, 04:41 PM   #10
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
bagged 5th cars are the bomb.
Old 12-25-2013, 05:05 PM   #11
PDP_SS
Drives: 2013 SS
Imma run 305's when I wear these tires out and I don't want bags tho it looks good it's not for me
What company makes the 2" drop springs
Old 12-25-2013, 05:17 PM   #12
BottleFEED
BottleFEED's Avatar
I want to say BMR made them I had to do a lot of looking around for them I bought them an a lot of other things all at once so I could be wrong. But I'm almost positive BMR made them. Now that being said the one thing I am running into is I am trying to put a 20x11 rim with 315's on the rear an I am unsure if it will fit or even a 20x10 305 as well. So if you want a for sure thing. Go with the 1.5 drop an that way you can put a 305 or 315.. Or you can get that extra half inch like me an be in the same boat lol. Let me know what ya do if you go for 2 or not I wanna know what you manage to fit under there.
Old 12-25-2013, 08:51 PM   #13
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 12-27-2013, 11:59 AM   #14
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
If you want to go lower than an inch you really need to consider coilovers. More than an inch will take the shocks and struts out of there normal travel range during normal driving and result in poor ride quality and premature failure. I have seen and replaced many o.e. shock and strut assy for that reason, including my own.
Piccione Performance is offline   Reply With Quote
