JDP Motorsports
Old 12-25-2013, 02:53 PM   #1
Suprslo
Drives: 2013 SS
Installing a JDP tow hook today
Just wanted to share what I'm doing today. My lovely wife got me a tow hook for Christmas and encouraged me to install it today. So I've never done this nor did it come with instructions but after a few google searches I felt i could do it. I was most nervous about removing the front fascia. After it was removed I'm not sure why I was so scared lol. It was super easy. Here is a few pics of where I'm at...
Suprslo is offline   Reply With Quote
Old 12-25-2013, 02:55 PM   #2
Suprslo
Drives: 2013 SS
This was the easy part. Make sure you mark where you want the hook BEFORE removing the fascia.
Old 12-25-2013, 02:58 PM   #3
Suprslo
Drives: 2013 SS
My only hiccup to this point was this connector. I had the front end literally off and didn't disconnect this. I had to hold the front end in one hand and unplug this with the other. No fun....
Old 12-25-2013, 04:29 PM   #4
Suprslo
Drives: 2013 SS
Ok so everything is done and I think it turned out well. I had to remove the front end a couple times to get the hook aligned just right. I'm really surprised this hook didn't come with a template for drilling holes. There are plenty of reference points to go off of. I would of cut an hour off the install time had I not had to adjust the hook so many times. This was my first time ordering from JDP and everything went great. They are good people to deal with.
Old 12-25-2013, 04:30 PM   #5
Suprslo
Drives: 2013 SS
Old 12-25-2013, 04:32 PM   #6
Suprslo
Drives: 2013 SS
Another angle
Old 12-25-2013, 04:35 PM   #7
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
tow hook
great job! i have to do mine here shortly.
OHIO SPEED is online now   Reply With Quote
Old 12-25-2013, 04:39 PM   #8
Suprslo
Drives: 2013 SS
Thanks!
Old 12-25-2013, 05:27 PM   #9
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
How did you measure to figure out where to drill holes? Or did it come with a template?
Looks great!
BigBlock69RS is offline   Reply With Quote
Old 12-25-2013, 05:33 PM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Looks great!
If you read his DIY you'll see he said there was no template and what he did to measure the holes.
Sent from my AGM, 2SS/RS
FSP tuned: 377/389
Old 12-25-2013, 05:34 PM   #11
nyrfan
Let's go Rangers!
nyrfan's Avatar
Dup post
FSP tuned: 377/389
Old 12-25-2013, 05:50 PM   #12
Suprslo
Drives: 2013 SS
BigBlock before I took the bumper off I used I long pic to mark where the hook should go. Basically centered it so it'd come through the grill. Once I drilled the holes where I marked them I installed the tow hook. It has Oblonged holes so you can fine tune where it comes through the grill at. As long as you're patient it'll turn out fine
Old 12-25-2013, 05:51 PM   #13
Suprslo
Drives: 2013 SS
In the second picture you can also see where I marked the support with a sharpie.
Old 12-25-2013, 09:33 PM   #14
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
This is on the to-do list with the new ZL1 bumper in the spring. Looks good!!
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
