HeadlightArmor
Old 12-26-2013, 05:39 PM   #1
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
Meth kits
What are some of the better kits out there and why? The Alky kit looks awesome.
One Bad Vert
......to be continued
Jpb972 is offline   Reply With Quote
Old 12-26-2013, 06:16 PM   #2
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Alky Control hands down. Why? Because Stone Cold said so.
D1SC Procharger 881/773 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 12-26-2013, 06:17 PM   #3
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
One Bad Vert
Old 12-26-2013, 06:44 PM   #4
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Nice!! +1 for Alky
+2 for Stone Cold
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 12-26-2013, 06:59 PM   #5
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
I see a lot of guys using Alky on this forum, but only this forum. Everywhere else I have customers using AEM, Snow Performance, or Aquamist. There's a lot of companies out there, just make sure to research them ALL to ensure you get the best kit.
I've used AEM, Snow Performance and Aquamist on a variety of different customer cars.
ModBargains.com is offline   Reply With Quote
Old 12-26-2013, 07:25 PM   #6
thebeast916
Drives: Blown G8 GT
I will be using coolingmist. Other option was alky control.
thebeast916 is offline   Reply With Quote
Old 12-26-2013, 07:31 PM   #7
Chris82xx
Chris82xx's Avatar
One of the reasons Alky is so popular is that when you purchase it, it already comes with a built in fail safe. Other companies offer it, but as an added purchase. Meaning, you have to purchase it separately
811RWHP/719RWTQ
Old 12-26-2013, 07:41 PM   #8
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
What fail safes does it have? Your not referring to the LED lights are you?
I'm curious cause I might be going to a Alky as well
SOLD-ZL1 M6:BTR,LTs,IDs,ATI,RotoF, AFCO. 10.84@129
SOLD-2011 SS M6: Blower, Cam, LTs, Alky.
Ron_Robinson1 is online now   Reply With Quote
Old 12-26-2013, 07:44 PM   #9
Ron_Robinson1
I have been interested but I was under the impression that there is no real "fail safes", the LED feature is really nice and will at least let you know it is working. It will indicate pump activation and change color when the pump reaches 100% speed. Problem is, this will still light-up if the pump fails!!
I'm not trying to sharp shoot you haha, but I might go Alky like I stated. I have been running devils own with a progressive controler and have been really happy. But from what I read Alky leads the way..
Old 12-26-2013, 07:47 PM   #10
ModBargains.com
AEM's system is a bit more advanced. I know it's not a company most guys would think about going with on this forum since AEM is a company that is more related towards JDM cars, but nonetheless, the system works, and it works VERY well:
I'm not going to copy and paste everything from AEM in regards to their failsafe, mainly because it's about 10 paragraph's long with pictures, more data and so forth, but it's absolutely worth the read if you're serious about Water/Meth injection:
http://www.aemelectronics.com/gauges...afe-device-56/
Old 12-26-2013, 07:51 PM   #11
Ron_Robinson1
AEM flow guage is awesome, if it works, like it shows and says it will. That's honestly the best fail safe I can see for methanol, but I'm yet to see one in action in person.
Old 12-26-2013, 07:59 PM   #12
ModBargains.com
With all the companies that I've worked with in the past, all the kits that I've sold for Meth, AEM is the only one I'd consider on my car, unless of course a company comes out with new hot product that proves itself to be better. I think a lot of guys on this forum just don't consider it because the name.
Old 12-26-2013, 08:34 PM   #13
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
Will AEM's system support 100% meth? Or anything over 50/50 for that matter?
One Bad Vert
Old 12-26-2013, 09:23 PM   #14
Chris82xx
Chris82xx's Avatar
No, the LED's are just a way to read how much meth is being pumped, at least one LED. The other just tells me when I'm running low. My meth is activated by boost, and it's tuned to activate only so much meth. If for some reason I'm driving and I run out, the car will fall flat on it's face. Not in the sense you might be thinking though. If I run out, the car will only run as if it's in "limp" mode only allowing me to rev the car so much and go only so fast.
811RWHP/719RWTQ
