Emblempros
Old 12-27-2013, 01:01 PM   #29
Joe@CPR.com
Joe@CPR.com's Avatar
Drives: 03 vette, 94 trans am, 04 gto
We prefer Alky control here, the push lock systems are junk imo. they eventually will leak along.
Joe@CPR.com is offline   Reply With Quote
Old 12-27-2013, 04:22 PM   #30
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
Just ordered my Alky kit from ECS! I feel confident that it's an awesome system. Quality of fittings and hoses, equipment designed for 100% meth, and a 2 bar map sensor all played a part in my decision. The optional 4 gal custom tank for the trunk is sweet! Can't wait to see and feel the benefits.
Adding the Alky kit, 3.33 pulley, and a filter w/ restrictor plate from ECS, all at the same time. Any guesses what my hp increase will be?
Jpb972 is offline   Reply With Quote
Old 12-27-2013, 05:51 PM   #31
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
What blower are you running specifically?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 12-27-2013, 06:05 PM   #32
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I gained 80rwhp by adding meth and increasing boost 1psi
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.8@143mph
bct10985 is offline   Reply With Quote
Old 12-27-2013, 06:10 PM   #33
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
Novi 1200sl
Old 12-27-2013, 06:11 PM   #34
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
What's your total boost?
Old 12-27-2013, 06:40 PM   #35
Chris82xx
Chris82xx's Avatar
Novi 1200sl
If I had to guess, with a restrictor plate, you'd be at about 650.
811RWHP/719RWTQ
Old 12-27-2013, 08:28 PM   #36
bct10985
Around 12.5
Old 12-30-2013, 07:09 AM   #37
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
Im seeing that there are different types of meth. M1,M3, etc. what are you guys using with the Alky kit?
Old 12-30-2013, 07:09 AM   #38
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
That works!!
Old 12-30-2013, 07:40 AM   #39
Unreal
Drives: 2006 Z06
100% meth from local fuel distributor. That would be like M1 I believe if you are buying it from VP.
Nick
Corvette Z06 -1200ish rwhp
Old 12-30-2013, 08:19 AM   #40
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Did you tune the AFR after adding the meth, or does it just spray before the IAT sensor so the computer sees the colder air and adds timing because of it?
Also, what % Meth/Water are you running? Like 50/50?
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 12-30-2013, 08:21 AM   #41
bct10985
Yes it was retuned for the meth. 75/25 meth/water
Old 12-30-2013, 08:25 AM   #42
grocerygetter
instigator
grocerygetter's Avatar
anyone got a pic of that optional 4 gal trunk cell? installed.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
