Caryle Racing
Old 12-30-2013, 09:39 AM   #43
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
Originally Posted by grocerygetter View Post
anyone got a pic of that optional 4 gal trunk cell? installed.
It's on JDP's website
Jpb972 is offline   Reply With Quote
Old 12-30-2013, 02:12 PM   #44
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Originally Posted by bct10985 View Post
Yes it was retuned for the meth. 75/25 meth/water
What AFR are you running now? Any idea how much it lowered your IAT's at full boost on a long pull?
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 12-30-2013, 02:26 PM   #45
grocerygetter
instigator
grocerygetter's Avatar
http://www.jdpmotorsports.com/alky-c...s-ak-10cam-kit
the Jaz fuel cell is the white one and the AIS tank is the black one with the nice molded trunk corner mount?
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 12-30-2013, 02:40 PM   #46
BUMBLEBEE_SS
BUMBLEBEE_SS's Avatar
Drives: 2010 SS LS3 S200 56/61 AGP TT
What gauges are you guys using for the meth?
I'd like to have one to know when I'm spraying and a fail safe type.
Any recommendations? Any brand ...
BUMBLEBEE_SS is offline   Reply With Quote
Old 12-30-2013, 02:50 PM   #47
Unreal
Drives: 2006 Z06
Alky Control
Wideband and Aeroforce
Can see AFR and IAT.
Without meth end of dyno pull was ~140F, with meth ~75F on a 70F day. That is stationary on dyno. On street temps are usually 10-20F below ambient when meth is on.
Nick
Corvette Z06 -1200ish rwhp
Old 12-30-2013, 02:57 PM   #48
1LESSPROBLEM
Drives: blown
Alky Control kits. the TBSS, G8 community, as well as the CTS-V community uses them pretty heavily. Hands down the best kit. Use 100% meth only, more octance means more power. To this day i still dont see why anyone would want to spray water into a motor.
VF Commodore
LSA
Heads
Cam
Weld
1LESSPROBLEM is offline   Reply With Quote
Old 12-30-2013, 03:43 PM   #49
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
Originally Posted by Unreal View Post
Alky Control
Which one allows you to see both?
Old 12-30-2013, 03:47 PM   #50
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Not sure on my afr after the meth. The graph i have doesnt show afr. Tuner said meth dropped temp by about 40°. If i remember before the meth it got up to around 160 on the dyno.
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.8@143mph
bct10985 is offline   Reply With Quote
Old 12-30-2013, 04:09 PM   #51
Unreal
Drives: 2006 Z06
How much AFR Drops depends in your set, airflow, fuel, and settings/nozzle sizes. I can drop .4 or 2 points depend on how much I spray.
Nick
Old 12-30-2013, 04:56 PM   #52
BUMBLEBEE_SS
Alky Control
You should know this. What meth kit are the boys using at AGP?
Old 12-30-2013, 05:39 PM   #53
Unreal
Drives: 2006 Z06
They are using AEM controllers but a lot of the other parts they are making in house. Kit comes preplumbed for meth so they are working on an add on option where you plug in the meth kit and are good to go. All lines/mounts/etc all setup.
So I would say it is an AEM/AGP hybird kit.
That being said, I have an alky control kit. I just eat lunch there daily BSing about cars so I would call Kevin if you want more info. Today we barely talked about cars, was mostly gun talk. Got to shoot my new AGP takedown 10-22 rifle I got for x-mas. Tons of fun.
Nick
Old 12-30-2013, 06:43 PM   #54
Jpb972
Jpb972's Avatar
Drives: 2011 2SS/RS
The only gauge I could find to give you IAT and AFR. Or whatever else you want for that matter.
http://www.veisystems.com/products/c...r-Fuel%20Ratio
Old 12-30-2013, 07:00 PM   #55
Slowhawk
Drives: 1999 Trans Am
Most customer cars I tune in at 11-1 to 11.6-1 on meth and without it they are about 1 point leaner.
My personal car is almost 3 points richer.
Slowhawk is offline   Reply With Quote
Old 12-30-2013, 07:34 PM   #56
dan0617
dan0617's Avatar
Check dynotunenitrous. They have a nice digital gauge that has a split screen so it is 2 gauges. I have one with AFR and Boost, matches the stock dash color pretty well.
