SDTW Custom Wheels & Tires
Old 12-27-2013, 03:52 PM   #1
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
Cost of Turbo vs. Super?
Hi everyone,
Have been looking around, and have seen a few threads saying S/Cs typically cost less than Turbos.
From a quick scan of different mods sites, I see turbo kits like Turbonetics for <$6K, and bunch of S/C kits (maggie, whipple) for ~$7.5K. Am I missing some piece of the cost? Guessing it costs more to install / maintain a turbo?
If anyone has any real numbers to compare would be much appreciated.
Thanks for any help!
2013 AGM 2SS/RS
SLP TVS2300, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square), GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, white rally stripes, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 12-27-2013, 04:04 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I don’t have numbers, but the centrifugal SCs like IPF can be less expensive due to simpler installation compared to turbos, maggie, or whipple. Tuning a turbo, maggie, or whipple may be more complex (and expensive) than the tune included in the IPF SC. The trade-off is that power output with centrifugal SC may be lower than turbo or PD SC.
Mark114 is offline   Reply With Quote
Old 12-27-2013, 04:21 PM   #3
Unreal
Drives: 2006 Z06
Install is easy, maintence is no more.
It gets to be an even bigger difference when you start to add headers, 8 ribs, pulleys, tensioners, heat exchangers, spacers, od rear kits, cold airs, etc.
As for the IPF stuff, this the v8 section, not v6 section. Not even sure they make v8 kits.
Nick
Corvette Z06 -1200ish rwhp
Old 12-28-2013, 07:10 PM   #4
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
I have a turbonetics t76 kit and outside of the kit cost and install
You'll need a
Boost controller/boost gauge
Wide band
A pillar gauge pod
I'd suggest other mods (same as sc cars) would be suspension work. You don't want to add all that power with out beefing up the suspension
I added
Trailing arms
Toe links
11 inch rims
Subframe bushings
With a sc set up you'll most likely add a cold air intake and headers my turbo kit uses stock manifolds and utilizes the stock parts for the air intake. I used a cold air inductions filter instead. Headers can be expensive too. One of my favorite features of the turbo is I can crank up the power for the situation I'm in with the boost controller.
Either way keep in mind once you add any forced induction the game changes and the car becomes a money Pitt good luck
Either way you go think out your supporting mods. Pm me if you have any turbo questions
1969to2010 is offline   Reply With Quote
Old 12-29-2013, 10:29 PM   #5
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
I'm all about the supporting mods at this point. I didn't listen, again, and went turbo and now my car can not put the power to the road. Sure 60 MPH burn outs are fun and impressive, but a car with 620 RWHP that still runs 12 second 1/4 mile times is hardly worth the expense.
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 12-30-2013, 12:00 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
The bottom line for cost is how much power do you want to make. It is much more expensive to go up in small steps than to make big changes. Like everyone else has commented, it is not so much the cost of the turbo or supercharger but the cost of the exhaust and intake mods and all the cooling changes and fuel pumps and injectors and clutches, blocks, rods and pistons....
I personally think the superchargers are a little less money for moderate horsepower gains. If you want big power (more than 750 whp) it would probably be cheaper to start straight out with the turbos.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 12-30-2013, 12:36 PM   #7
STSL
Drives: 2010 ZR1 Camaro
Im afraid even with suspension your not going to get great times with a turbo and a clutch.Give me a call and ill give you some tips on rear alignment the will get you headed in the right direction.
STSL is offline   Reply With Quote
Old 12-30-2013, 01:42 PM   #8
jessrayo
Speed Freak
jessrayo's Avatar
Are you on drag radials? If you want respectable 1/4 mile times you have got to switch to a drag tire or you will NEVER get the car to hook.
Old 12-30-2013, 02:09 PM   #9
Joe@CPR.com
Joe@CPR.com's Avatar
Drives: 03 vette, 94 trans am, 04 gto
AGP base kit for a manual is $7500 and we include shipping. includes everything needed for install, if you want to add gauges or a boost controller you easily can for not much more. Install is roughly 10-12 hours.
Joe@CPR.com is offline   Reply With Quote
Old 01-03-2014, 12:20 AM   #10
CyberPredator
50 Shades of Prey
Drives: TT/SS
OP Twin turbo kits are the ones that you hear of that are more than a supercharger. Superchargers catch up quick in price though when you need supporting mods to make the same power as bolting on a turbo kit.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 01-03-2014, 03:17 AM   #11
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Either way it gets pricy. Figure out your goals and go that direction. Like it's said, " you gotta pay to play"!
11TexaSS is offline   Reply With Quote
Old 01-03-2014, 09:58 AM   #12
TheMeat
TheMeat's Avatar
Drives: 1973 Camaro
See this a lot.
73 Camaro, 6.0 LS, Billet S480, E85, 4L80E.
TheMeat is offline   Reply With Quote
Old 01-03-2014, 10:11 AM   #13
Unreal
Drives: 2006 Z06
600-650 isn't that hard to hook. Tires and maybe some bushings do wonders. Tires alone will hook 600rwhp. It amazes me how many people try to go fast on stock tires/wheels.
Nick
Old 01-03-2014, 11:25 AM   #14
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
