Old 12-28-2013, 03:28 PM   #1
Msmall143
Msmall143's Avatar
Drives: Camaro
Wtf is going on - car seems 1-2 inches higher after having it on jack stands
I had my car on jack stands to install my air scoop. I placed the jack stands where I read I hear to place them. Deffinitally on the frame.
I just dropped the car and initially noticed a larger wheel gap. Then I realized the front splitter is higher off te ground than normal.
What the hell is going on? Does the car take time to set. It was on jack stands "front only for 4-5 hours.
Msmall143 is offline   Reply With Quote
Old 12-28-2013, 03:33 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
When you finally drive it it will very quickly move back to its original height. happens to me all the time and when I pull out of the garage it is back to normal.
kjkjr27 is offline   Reply With Quote
Old 12-28-2013, 03:53 PM   #3
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Once load is placed on the suspension (aka driving the car) it will settle and return to normal height.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 12-28-2013, 03:58 PM   #4
Msmall143
Msmall143's Avatar
Drives: Camaro
Cool, I was just going to drive it and see but I didn't have a extension for my torque wrench so I dont have the lugs torqued yet. Just went and bought the .5 inch to .5 inch extension
Thanks for the quick response!
Old 12-28-2013, 05:49 PM   #5
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Once you roll the car it will start to drop back down. The main reason this happens is because when you pick the car off the ground the distance from the right tires to the left tires decrease. When you set the car back down the tires grip the surface and won't slide fully back into its original spots. You can see and hear this happen when you pick the car up and the tires slide across the surface until they don't touch.
cylinder head and throttle body porting
11.3s @ 120 in the heat at CamaroFest7
Old 12-28-2013, 05:53 PM   #6
Oliv59
Oliv59's Avatar
Drives: 45th M6
This!
A little bit disturbing the first time. Like OP mentions it.
Oliv59 is offline   Reply With Quote
Old 12-28-2013, 10:55 PM   #7
Msmall143
Msmall143's Avatar
Drives: Camaro
Well, at least I know what a 2 inch lift kit would look like!
Old 12-29-2013, 07:00 PM   #8
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Should have told him he was going to have to let some fluid out of his struts..LOL
Eddiefuzz is offline   Reply With Quote
