Old 12-29-2013, 12:17 PM   #1
bcasurvey
bcasurvey's Avatar
Drives: 2014 2ss rs a6
battery saver active on display
so ever time I start the car I get a message, "battery saver active" its been doing it for a week now, it started shortly after I put an amp in for my sub. but battery and alt seem ok, I did a search but didn't come up with much, im going to test the system today but I don't think its going to read low, as the gauge shows ok, any ideas.
bcasurvey is offline   Reply With Quote
Old 12-29-2013, 12:22 PM   #2
Detleg
DNFT
Detleg's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
Send a message via Yahoo to Detleg Send a message via Skype™ to Detleg
here ya go
http://www.camaro5.com/forums/showthread.php?t=162858
Detleg is offline   Reply With Quote
Old 12-29-2013, 01:02 PM   #3
bcasurvey
bcasurvey's Avatar
ok this is what its doing, before I start the car it has 12.5v then when I start the car the voltage goes up to 14.4 volt, then after sitting idling for a few minutes the voltage drops back to 12.5 volts, its like the alt quits charging at full charge after running for a few minutes, and just stays at the 12.5v, no problem starting or running anything, I guess my alt is going bad?
oh and thanks for the link above, I have read it but it didn't help my problem.
Old 12-29-2013, 05:05 PM   #4
bcasurvey
bcasurvey's Avatar
update: started and went to 14.4v drove around and as soon as I stopped at a stop sign it went to 12.5v and stayed there and wouldn't come back up till I restarted the car, I guess my alt is going bad, message wont go away on start up.
Old 12-29-2013, 05:11 PM   #5
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
you have an auto trans?
part of the AFM system is alternator voltage reduction if the computer determines that the higher voltage is not needed.
meaning @ idle and cruising unless you have the lights on, are pushing the sounds system, etc the vehicle has decided to reduce the drag on the vehicle by scaling back the voltage because it doesn't need it.
this has been on every GM vehicle with AFM since it came out.
insofar as your alert that battery saver mode was active, check and be sure you do not have something draining the battery when the vehicle is off:
phone charger, interior lights left on, etc..
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 12-31-2013, 04:52 PM   #6
bcasurvey
bcasurvey's Avatar
update: range mod installed, charged battery over night and its still doing it, I guess its going to the dealer next week.
Old 12-31-2013, 05:36 PM   #7
bcasurvey
bcasurvey's Avatar
12/2013=range mod, cai intake, kooks lt 1 7/8 w/ hf cats, borla s-type cat back,
stock no mods=1/4mi. 13.189, 106.628 mph
slp tvs2300
Old 12-31-2013, 06:06 PM   #8
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
If it started "after" you did the amp install, disconnect the amp power feed, charge the battery and see what happens for the next few days.
etmx183 is offline   Reply With Quote
Old 12-31-2013, 06:43 PM   #9
bcasurvey
bcasurvey's Avatar
thanks I will try that this week before taking it to the dealer, sometimes it just take a second opinion.
slp tvs2300
Old 12-31-2013, 09:01 PM   #10
Mr. iNCREDIBLE
like I said, check and see if something isn't draining the battery.
