Old 03-24-2008, 04:49 PM   #1
Mythic
Mythic's Avatar
Drives: '03 Monte Carlo SS
Air Ride?
Anyone thinking about an air ride system?
maybe lower the car but still able to clear those damn speedbumps.
Mythic is offline   Reply With Quote
Old 03-24-2008, 05:37 PM   #2
NOODLESgoneWILD
IS IT 2009 YET???
NOODLESgoneWILD's Avatar
Drives: '05 Z51 Black Vette & '06 H2
Send a message via MSN to NOODLESgoneWILD
Without a doubt...I'd love to have something like that. It would be great to go to cruze night...roll in low and slow, and drop it on the ground...then when you ready to hit the road and lay a patch of rubber, you could bump up the ride height to do it.
Don't love me just for my FBod
NOODLESgoneWILD is offline   Reply With Quote
Old 03-24-2008, 06:39 PM   #3
blindingillusion
blindingillusion's Avatar
Drives: 2008 Chevrolet Cobalt 2LT
heavy....
Ordered:
2010 Black 2SS/RS
-CGM Ralley Stripes
-Hurst Short Throw Shifter
-20" Polished Aluminum Wheels
Has Owned:
2008 Cobalt
1996 Monte Carlo
1988 Sierra
1979 LeSabre
blindingillusion is offline   Reply With Quote
Old 03-24-2008, 08:58 PM   #4
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Hopefully this bose suspension they are eventually coming out in the future will have a feature to adjust ride height.
Kyle2k is offline   Reply With Quote
Old 03-25-2008, 10:17 AM   #5
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
Not to Familiar with air ride. had a buddy with a chevy truck that had air ride on it. whats the pros and cons?
TFord is offline   Reply With Quote
Old 03-26-2008, 07:36 PM   #6
camarocrazy28
camarocrazy28's Avatar
Drives: 1990 Camaro RS
Adjustable ride height, superb handling because of incredible tunability, and a comfortable ride. Those are the pros. Cons would be cost and availabilty. Nothing for 5th gen Camaros yet. I want air ride for my 3rd gen.
camarocrazy28 is offline   Reply With Quote
Old 03-27-2008, 06:43 PM   #7
Sinister
Satan's Boss!
Drives: 1985 Z-28/IROC-Z
Send a message via MSN to Sinister Send a message via Yahoo to Sinister
I'll be putting an air ride system in my car over the next winter...but I do agree with the pros & cons that camarocrazy28 posted.
check out this site--->http://www.ridetech.com
Sinister is offline   Reply With Quote
Old 03-27-2008, 10:11 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Could someone be a pal, and just sum up really quick what an "Air ride" is for me?
It's a type of suspension system...I got that much - but what is it? Briefly, how does it work?
Old 03-28-2008, 08:32 AM   #9
Mythic
Mythic's Avatar
http://en.wikipedia.org/wiki/Air_suspension
The installation and configuration of these systems varies for different makes and models but the underlying principle remains the same. The metal spring (coil or leaf) is removed, and an air bag, also referred to as an air spring, is inserted or fabricated to fit in the place of the factory spring. When air pressure is supplied to the air bag, the suspension can be adjusted either up or down (lifted or lowered).
For vehicles with leaf spring suspension such as pickup trucks, the leaf spring is sometimes eliminated and replaced with a multiple-bar linkage. These bars are typically in a trailing arm configuration and the air spring may be situated vertically between a link bar or the axle housing and a point on the vehicle's frame. In other cases, the air bag is situated on the opposite side of the axle from the main link bars on an additional cantilever member. If the main linkage bars are oriented parallel to the longitudinal (driving) axis of the car unbolt the motor mounts and the bags will hold it up and make it bounce, the axle housing may be constrained laterally with either a panhard bar or watts linkageor you could take a shaft out of a old 72 Ford and it is uncanstrable from the bags. In some cases, two of the link bars may be combined into a triangular shape which effectively constrains the vehicles axle laterally.
Often, owners may desire to lower their vehicle to such an extent that they must cut away portions of their frame for more clearance. A reinforcement member commonly referred to as a C-notch is then bolted or welded to the vehicle frame in order to maintain structural integrity. Specifically on pickup trucks, this process is termed "notching" due to the fact that a portion (notch) of the cargo bed may also be removed, along with the wheel wells, to provide maximum axle clearance. For some, it is desirable to have the vehicle so low that the frame rests on the ground when the air bags are fully deflated.
Old 03-29-2008, 02:20 PM   #10
fastball
White 'n Nerdy
Drives: 2017 Camaro 2SS 6MT
Sorry, when I see or hear "air-ride" I think of one of two things:
1. A 1980 Cadillac with it's rear end dragging (because the air shocks and/or pump are shot)
2. Any gangsta rap video and a 1963 Impala
I'll take my gas struts and coil springs, thank you.
fastball is offline   Reply With Quote
Old 03-29-2008, 02:27 PM   #11
Mr. Wyndham
I think of sleeping on a cloud.......
Old 03-29-2008, 03:13 PM   #12
Mythic
Mythic's Avatar
It certainly isnt cheap a set for the 67-69 Camaros is nearly $7k
Vehicles that use air suspension today include models from Maybach, Lexus, Mercedes-Benz, Land Rover/Range Rover, SsangYong, Audi, Subaru, Volkswagen, and Lincoln, among others.
http://www.hotrod.com/howto/hrdp_070...mpressors.html
Especially read the bit about the Red 67 Chevelle vs the Blue 66
Old 01-18-2010, 11:29 AM   #13
reedikyaluss
reedikyaluss's Avatar
Drives: 2005 Chrysler 300C
You're talking about hydraulics.
reedikyaluss is offline   Reply With Quote
Old 02-02-2010, 12:05 PM   #14
Cmlloveless
Drives: 2010 2SS RS
So any idea if any company has a Camaro specific kit in the works?
Cmlloveless is offline   Reply With Quote
Bee-otch. air freshener byebyeImports Off-topic Discussions 17 08-10-2009 03:52 PM
Transformers: The Ride? BumbleBee 5th Gen Camaro SS LS LT General Discussions 5 01-30-2008 10:23 PM
United States Air Force PureEvil Off-topic Discussions 6 12-15-2007 11:46 PM
Cobalt's air tests cleanest KILLER74Z28 General Automotive + Other Cars Discussion 0 03-20-2007 06:08 PM
