JUICEDMOTORSPORTS
View Poll Results: Vortex or Paxton supercharger
Vortex 4 26.67%
Paxton 5 33.33%
Other 6 40.00%
Voters: 15. You may not vote on this poll
Old 01-02-2014, 07:32 PM   #1
greatmike
Drives: 2010 silver 2SS/RS Camaro
Vortex or Paxton supercharger which is better.
Looking to do a super charger upgrade .either Paxton or vortex.which model for a daily L99 street driver with headers , slp pulley ,kn intake and JRE tune.
greatmike is offline   Reply With Quote
Old 01-02-2014, 07:48 PM   #2
blake-b
blake-b's Avatar
Drives: Black 2010
Paxton and Vortech are the same company.
Give ECS or Matt@FSP a PM or call and talk to them about what is best for you
Old 01-02-2014, 07:48 PM   #3
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
ECS kit. Vortech or Paxton. Read my sig. Ted can tune the ECS setup just fine. Get the ZL1 pump, the ADM FPCM and the ID850 injectors. You will be glad you did.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 01-02-2014, 08:02 PM   #4
greatmike
Does the ecs set up pic up more hot air from drop near radiator more than others.
Old 01-02-2014, 08:29 PM   #5
Unreal
Drives: 2006 Z06
Where the air filter is doesn't matter nearly as much as the intercooler and efficency of the system. Running a pipe to pick up cooler air cost more power because of the bends/restriction. If you want to make less power you could buy a vortech inlet tube but most people are ditching them and just running the filter off the blower like ECS.
As Blake said, paxton and vortech are the same company. Paxton uses billet cases and vortech cast. No different in performance, just bling looks really.
Either way, the SLP pulley, intake and tune will have to be swapped out.
Nick
Corvette Z06 -1200ish rwhp
Old 01-02-2014, 08:33 PM   #6
greatmike
Power all about the same on Paxton novi esc. And vortex v7 or v3.
Old 01-02-2014, 08:37 PM   #7
Unreal
Drives: 2006 Z06
Si trim is a 1200
T trim is a 1500
JT trim is a 2200
YSi is a 2200R
Same wheels, same internals. Now the ECS kit makes more power from the better intercooler, piping, pulley setup, etc. As far the blower, a Paxton 1500SL is the same exact blower internally as a Vortech T trim so power output is the same.
Nick
Old 01-02-2014, 08:45 PM   #8
Joe@CPR.com
Joe@CPR.com's Avatar
Drives: 03 vette, 94 trans am, 04 gto
As stated they are the same.
Joe@CPR.com is offline   Reply With Quote
Old 01-02-2014, 08:48 PM   #9
greatmike
Thanks guys for the knowledge,just trying to do it right.
Old 01-02-2014, 08:58 PM   #10
greatmike
I like the look of the ecs kit but heard bad feed back on it and there shop.want to keep my tune with JRE. If possible .
Old 01-02-2014, 11:07 PM   #11
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Im not sure where you got that info but u need to do a little more research. ECS is one of the most popular and reputable supercharger companies in the vette and 5th gen camaro world.
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.8@143mph
bct10985 is offline   Reply With Quote
Old 01-02-2014, 11:18 PM   #12
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
My car is down at them right now getting a blower swap and a head swap. They are the only ones who have touched my car when it comes to engine work. The only time I haven't was when I did a clutch upgrade. It wasn't worth the time to bring the car an hour and a half away for something that my local transmission shop can do. You're about 30 miles away from me, feel free to ask any questions. I can even give you directions from where you're at.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 01-02-2014, 11:22 PM   #13
dan0617
dan0617's Avatar
I love my ECS setup and have not had a single problem. NO belt slip whatsoever with their tensioner setup. Most other out of the box kits need relocated and new/better tensioners even on the standard pulley, let alone if you swap down to a smaller pulley.
Old 01-03-2014, 08:25 AM   #14
Unreal
Drives: 2006 Z06
If that is the case then no reason asking any of us, do what Ted says. That being said you can find bad stuff about any vendor. I've spent plenty at ECS and Doug/Chris are awesome. Matt@FSP use to work for ECS and is one of the best vendors around if you rather buy stuff from him. He has awesome deals on ECS kits and is a great tuner.
That being said, look into all the options. Procharger makes a nice kit too, AGP makes a awesome twin turbo kit, Whipples are ok. No reason to limit yourself to paxton/vortech.
Nick
