Old 01-02-2014, 07:47 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question Turbos for twin setup
What size turbos would you go with for a twin turbo setup on the LLT V6?
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 01-03-2014, 01:22 AM   #2
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Depends on the turbo maker on what size. Certain "T" size turbos equal certain "mm" sizes. I have 58mm BW and many say it's to big for the LLT and meant for the SS. But the LLT spools it up good.
Sent from my Samsung Galaxy Note 3
Can't_C_Me is offline   Reply With Quote
Old 01-03-2014, 02:33 AM   #3
2010_camaro
Well I'm unsure if I'm going single or twin. I'd like to go twin under the hood. But may go single under the hood.
Old 01-03-2014, 02:46 AM   #4
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
A single will save you some cash, last i noticed that was a good thing
for real though going twins looks awesome but if you want to do a econo build a single setup would be your answer. next year i want to do a custom single turbo setup.
Mvp_Me is offline   Reply With Quote
Old 01-03-2014, 03:22 AM   #5
2010_camaro
Well I like the looks of twins under the hood. Single is cheaper and easier but where is the fun in that? Plus I have never seen a V6 with twins inder the hood. There is not a lot of room so I debated on going with two GT2560R turbos. They are rated for 330hp each. I doubt ill be hitting 600hp. I'd like to see 450-475 crank hp. I don't want to go to wild. But I'm just wanting some input on turbo sizes from people on twins and or singles.
Old 01-03-2014, 04:02 AM   #6
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
Old 01-04-2014, 11:04 AM   #7
2010_camaro
So trying to figure out where to put my twins and how on earth I could run the exhaust under the hood. Their seems to be a lot of room in there untill you try and cram turbos in it.
Old 01-04-2014, 03:54 PM   #8
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
turbos could go beside the transmission....
Old 01-06-2014, 06:43 PM   #9
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Under the hood twins not a good idea. This is why no one has done it. There was only one V6 out in the wild back in 2010. But it vanished and wasn't a actual running prototype.
Old 01-07-2014, 07:46 AM   #10
2010_camaro
Why is it a bad idea?
Old 01-07-2014, 12:12 PM   #11
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Space as well as extreme amounts of heat
Old 01-07-2014, 01:48 PM   #12
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
mmmmm turbo blanket???
Old 01-10-2014, 07:15 PM   #13
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
No space for engine bay mount parallel twins unless you don't mind cutting and moving everything in the engine bay. Even the ECU was moved in the SEMA twin turbo V6 Camaro prototype.
But to answer the OP's question, a wide variety of turbos can be used for twins, it all depends on how and when you want to feel the power.
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
Pt_killa is offline   Reply With Quote
Old 01-10-2014, 08:01 PM   #14
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Have to agree a single will fit but twin will be more difficult and things have to be moved in order for them to fit and then heat may be a issue .
Sent from my SAMSUNG-SM-N900A using Tapatalk 4
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
