Old 01-02-2014, 09:09 PM   #1
lsmaro
Drives: 2011 ls
boost range
does anyone have a idea of what the llt can safely boost with ipf supercharger and a bigger fuel pump like the zl1 pump
lsmaro is offline   Reply With Quote
Old 01-02-2014, 09:22 PM   #2
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
I think Arno said 10 psi was the most you could put through.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is online now   Reply With Quote
Old 01-07-2014, 08:23 PM   #3
lsmaro
Drives: 2011 ls
why are these motors limited to 10psi is it because the CR or lack of forged internals
Old 01-07-2014, 08:40 PM   #4
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
That and a lack of fuel
Sent from my iPad2 on space mountain
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 01-07-2014, 08:50 PM   #5
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Perhaps he's talking about the limit of the centri unit itself. The amount of fuel needed will be determined by the CFM air moving through. I'm not sure what that would be at 10 psi for the centri unit, but based on what I'm seeing for the dyno sheets for the IPF, I think that would be a little less than the limit for the HPFP. Just a guess on my part, but I think you can get 450 RWHP on a A6 and 480 RWHP on a M6 and still not max out the pump. I don't think you would get hose numbers with 10 psi on the IPF system. Well, maybe on Sycrafts car, but not any of the others I've seen. Again, just my opinion.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 01-07-2014, 08:53 PM   #6
blackTT600
Drives: 2011 2LT M6 SC
Arno told me i could go with a 10% smaller pulley making approximately 14LBS and id be good. i have yet to do this but its a fun idea to play with
blackTT600 is offline   Reply With Quote
Old 01-08-2014, 08:03 PM   #7
lsmaro
Drives: 2011 ls
with all bolt on mods, a supercharger, bigger fuel pump and bigger rear end gear ported intake would the llt break 500 or what would it be close to as far as hp/tq numbers
Old 01-08-2014, 08:56 PM   #8
MagnumForceGB
Good to know that, I was planning on going to a smaller pulley whenever I get replacement parts.
Old 01-08-2014, 09:52 PM   #9
MagnumForceGB
Here is the post I was referring to:
http://www.camaro5.com/forums/showpo...0&postcount=37
Old 01-09-2014, 10:38 AM   #10
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
But does he recommend it? I doubt IPF does...especially not with their warrantied setups. If you don't have their extended warranty, then I'm guessing they may not care.
But I was told by Arno (I think??...its been a while) that 9 psi was basically the max on the standard system and they felt that was a strong but safe level for an other stock LLT. I've never seen him say much about using a smaller pulley for more boost.
In fact, I've seen him say that using higher boost can result in less power in some cases ( I can't remember exactly why right now)...but if the tune for it is good, and the fuel is there I don't see why it wouldn't make more power.
Old 01-09-2014, 08:38 PM   #11
MagnumForceGB
Wonder if its from pulling timing due to too much boost.
Wonder if E85 would allow more boost, have a V6 run in the 9's.
Old 01-10-2014, 10:09 PM   #12
stevey_frac
Drives: 2010 LT2/RS Coupe
For clarification, does the stock kit run 9 PSI?
Could you turn up the boost to 9 psi easily if not?
Mods so far:
MRTv2 Exhaust
275 / 40 / 20 Continental ExtremeContact DW's on all corners
Next up:
Magnaflow Resonated X-Pipe (Purchased but not installed)
EBC Redstuff street pads
Carbotech XP8 / XP12 track pads
1LE Track Pack
Note: This car built by JDP Motorsports!
stevey_frac is offline   Reply With Quote
Old 01-11-2014, 03:50 PM   #13
MagnumForceGB
Stock kit on a stock car should hit 10 psi @ 7200 RPM's. If not you have a boost leak according to Arno. Once you add mods your boost will go down, like mine is at 8-9 psi since I have headers and ported intake manifold along with a few other mods.
Old 01-11-2014, 05:11 PM   #14
lsmaro
Drives: 2011 ls
great info guys. I will be supercharging this spring with a lot of other mods so just had to make sure I knew what I will be getting
