BeckyD@RodgersChevrolet
Old 01-04-2014, 06:08 PM   #1
KRich2587
KRich2587's Avatar
Drives: 2014 Summit White 1LE
installed Pfadt radius arm bushings
I'm slowly starting to do suspension mods to my 1LE. I cane a across a smoking deal from JDP motorsports for the radius rod bushings so i had to get them.
The quality of the parts is amazing, They almost look too good to put under a car. Installation was a bit annoying as they have to sit for 12 hours for adhesive to cure but besides that it's simple. After install i have no noticeable new noises, maybe a few clicks when off camber on a slope but nothing during normal driving. I do track the car so well see if i can tell any difference on track but on the street i notice better brake feeling and slightly more steering response.
All in all great product thank you Pfadt and JDP motorsports
Posted from Camaro5.com App for Android
KRich2587 is offline   Reply With Quote
Old 02-22-2014, 03:50 PM   #2
EarlyApex
Drives: 2013 IOM 2SS 1LE
Any hints on removing the radius rod from the spindle? I hate to resort to using a pickle fork, I am afraid of damaging the ball joint boots.
EarlyApex is offline   Reply With Quote
Old 02-22-2014, 09:11 PM   #3
Synner
Drives: not stock
Get the car up high enough to hit the stud with a really heavy hammer/sledge. Pickle fork will ruin the boot and its non-serviceable. Although if you go that route you can just buy a new radius rod, I think they're $25 or something along those lines and not too rough on the wallet.
Old 02-22-2014, 09:20 PM   #4
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
just got done doing this myself...
Heat up the knuckle with a propane torch (BE VERY CAREFUL OF RUBBER BOOTS)...
oh and a sledge with a sacrificial 10mm socket so you don't ruin the threads/joint socket
It was the only way I could get mine off.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 02-23-2014, 10:17 AM   #5
EarlyApex
I have it on my hoist at eye level. So far I've tried the propane torch and BFH on both the side of the spindle and end of the ball joint and just succeeded in mushrooming the end of the stud. If the arms are really that cheap the pickle fork might be the next step.
I got my 1" lowering springs installed and would have finished the rear sway bar except one of the bushings they sent is for a 1 3/8" bar instead of 1 1/8" so can't finish that until I get the right part.
Old 02-23-2014, 10:31 AM   #6
EarlyApex
Well, the control arms are way too expensive at $70 to $80 each to destroy.
Old 02-24-2014, 07:19 PM   #7
KRich2587
KRich2587's Avatar
I put the nut on the ball joint and used an air hammer on the stud to pop them out keeping the nut on keeps you from mushrooming it
Old 03-06-2014, 10:10 AM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
did you guys try smacking the spindle with a brass hammer like you would with a tie rod or ball joint?
real ZL1 wheels 285/305 Michelin Pilot Super Sports, Pray ported IM/TB, EFI Tuning Flex fuel kit, American Racing Headers long system w/ cats H pipe to NPP. 1LE suspension package.
JCunningham is offline   Reply With Quote
Old 03-06-2014, 11:28 AM   #9
Jerry7297
Jerry7297's Avatar
Drives: 2016 3LT Stingray RIP-2010 CamaroSS
Pictures or it didn't happen.
Would like to see this after complete. I used a brass hammer on mine. But then did not install my BMR bushings sold them.
Jerry7297 is offline   Reply With Quote
Old 03-06-2014, 08:00 PM   #10
KRich2587
KRich2587's Avatar
pics of what? the ball joint ends?
Old 03-07-2014, 10:46 AM   #11
EarlyApex
The install of the radius arm bushing is done. I bought a Kent Moore removal tool and that with some heat and a hammer was able to bet the ball joints removed. I did have to modify the tool to clear the corners of the nut and also buy a longer bolt but I am still only into is $25. The rest of the job was easy. I used my press to remove the stock bushings and press in the new. I marked the bushings to help in getting them centered. They are .400" in from the edge. I am getting the alignment today so I will know later how it feels compared to stock.
Old 03-07-2014, 11:13 AM   #12
Jerry7297
Jerry7297's Avatar
Pics of the Radius rod bushings installed. Like the ones early Apex posted. I just wanted to see the PFADT bushings installed.
Awesome pics EA.
Old 03-07-2014, 08:07 PM   #13
KRich2587
KRich2587's Avatar
I'll take pics tomorrow when its up on a lift
Old 03-07-2014, 09:23 PM   #14
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Perfect timing. I plan to do this job along with the cradle and diff bushings with a 32mm rear bar this week end.
Firefighter is offline   Reply With Quote
